Buy a rear clam Steve. This madness has gone on long enough.
frankenstein-clam is happening now
Posted 22 August 2018 - 09:37 AM
Posted 22 August 2018 - 10:29 AM
Posted 22 August 2018 - 10:47 AM
I think TDO's would have a problem. Caterhams and Atoms are proven road cars. Saying that they didn't have any issues with this
Posted 22 August 2018 - 05:14 PM
I very much respect and admire you for taking on a project like this, so fair play.
Just my opinion, and maybe it's because I have no 'vision' but think the design choices are a little odd, and very radical. Maybe it's because I can't picture the end result, or maybe it's because I picture it looking like somebody has glued together an Audi A4, VX220 and Toyota CHR
Posted 22 August 2018 - 06:14 PM
Posted 22 August 2018 - 07:05 PM
So the photo has the headlight just pushed in from the wheel arch & held in place with bubble wrapped shoved in from behind. I've fitted my old splitter (I think it looks better without a plywood splitter, but I want a splitter for the track, so it will have to stay. The car is jacked up on the side of the headlight, so the car may appear cocked. The bumper is not fitted properly at all, in fact, I ran out of time & just took a quick photo before closing the door.
I could have made a better job of the headlight cut out, it's a little off. even with making templates, due to the VX bonnet shape, it's tricky! I wanted a brow over the light like on some Audi's, but I cut it a little too straight. The other side should look better...
I'm going to use a perforated aluminium sheet that has been cut into strips to fit behind the plastic bumpers with voodoo glue (thanks FLD) to hold the cut bumper joints together so that it does not crack for when the mould is made. I may even try to add a liquid plastic mix which hardens & just sand it back & then fill?
From what I've seen today, the headlights with a little work will look just fine grafted onto the VX. I will have to make a fixing cradle for them though. it looks a little gappy as its just propped up from behind & its slumped back a little.
Hopefully next time I'll have both headlights done, arches trimmed & the bumper pieced together....hopefully!
Posted 22 August 2018 - 07:17 PM
Posted 22 August 2018 - 08:11 PM
Suspect you're not going to have the adjustment to get a level beam pattern with the headlights at that angle. Depending on the construction you might be able to alter the shutter to level them.
Posted 22 August 2018 - 08:20 PM
Posted 22 August 2018 - 08:33 PM
Posted 22 August 2018 - 08:41 PM
On the right hand side of the bumper it almost looks like the Audi bumper when cut down matches the contours and plane of the vx upper clam?
On the earlier photos it looked like there was a massive difference?
Posted 22 August 2018 - 08:52 PM
Posted 22 August 2018 - 09:02 PM
Posted 22 August 2018 - 09:30 PM
You are crazy but I like it.. Its what .org is all about.. Keep going.
Posted 22 August 2018 - 09:51 PM
Edited by smiley, 22 August 2018 - 10:08 PM.
Posted 23 August 2018 - 07:12 AM
Edited by mbes2, 23 August 2018 - 07:13 AM.
Posted 23 August 2018 - 09:13 AM
Are you going to fiberglass copy the plastic bumper as over time both materials normally show signs of fracture and cracking between the joins
I love the headlight change, it's the cars Achilles heel
Posted 23 August 2018 - 10:55 AM
Posted 23 August 2018 - 11:47 AM
I’d be interested in a fibreglass copy ðŸ˜, would be quite happy to have the mould made pending the final finished look etcAre you going to fiberglass copy the plastic bumper as over time both materials normally show signs of fracture and cracking between the joins
Posted 23 August 2018 - 04:13 PM
