yup and a bmw, im a proper wanker
Revised Vx Front End
#101
Posted 31 August 2018 - 08:19 PM
#102
Posted 31 August 2018 - 09:16 PM
im a proper wanker
#103
Posted 31 August 2018 - 09:24 PM
ive seen the light though...
bmw was great when it worked but keeping it working was more work and money than flymo!
#104
Posted 01 September 2018 - 06:45 AM
You're now driving a seat? I'm now going off them too!ðŸ˜
Stick with the flymo, don't keep ruining cars for me!
#105
Posted 01 September 2018 - 11:19 AM
It’s a brilliant car tho just needs a bit more poke
#106
Posted 01 September 2018 - 08:12 PM
I spent very little time on the car today due to a friend (single dad) who fell asleep at the wheel of his Discovery at 50+mph. He rolled the car in a ditch along a local road to me, through a hedge, glancing a tree & then rolling. Fortunately, he had just dropped off his two kids with friends an hour before. I had to go to the police compound to collect various belongings. The car was so badly damaged that it was barely recognisable. all airbags deployed, most windows had shattered, roof buggered, car toast.
I came back and couldn't really get motivated to do much other than a few minor alterations. I still need to move the front & headlights forward by 20mm and upwards by 10mm, which should give me 45mm vertical distance from tyre to headlight casing. I'm still unsure if this is enough? Any ideas?
Any help would be appreciated.
So, I started cutting up the bonnet, not much of it left at the moment. It's now flimsy a hell & each time I remove it on my own, I think it will break in two.
What do you think of moving the original bonnet front lip to where I have relocated it in the photo? Next step tomorrow is to do some more cuts on the bonnet to realign the top surfaces before making a start on bending some galvanised wire to form the headlight shape. It should make forming the new wing & bonnet curves to blend to the headlights & new located bonnet front edge easier. However, nothing can be started until I know the wheel travel will not foul the headlight under hard cornering and over bumps etc.
#107
Posted 01 September 2018 - 08:42 PM
yup and a bmw, im a proper jolly nice chap
Married life does that
#108
Posted 01 September 2018 - 08:43 PM
yup and a bmw, im a proper w.anker
Edited by Chris P Duck, 01 September 2018 - 08:43 PM.
#109
Posted 01 September 2018 - 09:44 PM
I just realised, my front wheels are 17'' Dia, I've got a new set of 16'' front wheels to fit. I'll try fitting them tomorrow after I have a couple of old tyres put on them.
#110
Posted 02 September 2018 - 05:27 AM
Not sure what your plans are for wheel arch liners, assume you won't have any as it's a track car? Could put a little guard / sacrificial plate over them as they would get covered in track rubber.
Really impressed with what you're doing BTW, looking forward to seeing the result.
Sent from my G8441 using Tapatalk
#111
Posted 02 September 2018 - 07:19 AM
I'll try fitting a wheel arch liner in, but It will mean having to cut a hole out where the rear of the headlight housing is closet to the wheel. Im pretty sure that the part of the headlight housing closet to the wheel is for one of the 3 adjusting mechanisms to adjust the light beam, so I can't really cut a portion off and weld the hole back up.
I could possibly plastic weld a cover or hot air gun a bulge back onto the liner (if the plastic is weldable /pliable) or super glue a bulge back on for those who may wish to keep their liners.
It's an interesting project, well for me it is. I don't feel so bad doing it to the VX, even if people decide to bastardise their cars, as front & rear clams are readily available now to buy. Future investors/ purists can then retrofit the original bodywork/ lights back as nothing else is effected by the conversion.
I've decided to not fit a plywood splitter back to my car, but I may fit the Audi aftermarket splitter which gives it a noticeable jutting chin as well as fitting a flat underside. I will be fitting a smooth curved base & sides within the crashbox. Perhaps add two staggered curved aero blades inside the crashbox to channel the air through the crashbox and up through the radiator with hopefully less turbulence and perhaps some extra free downforce. Clearly, this is just a total amateur guess. I may as well use the big hole in the middle.(don't smirk) to better affect if I can.
Guys, has anyone used their hollow sills to channel air back into the engine bay? I was amazed at how much space there is. They are just hollow tubes that go front to back. Now that Ive cut scoops in the rear sides for my intakes, it's all accessible and doable. Just a thought for anyone wanting another cooling option.
#112
Posted 02 September 2018 - 12:21 PM
#113
Posted 02 September 2018 - 01:42 PM
If your car is purely for track why bother with lights? You just put some blanks in.
I have had blanks fitted front & rear for several years, I have just removed them to do this conversion.
...I was going to part company with the VX as it is getting old now, troublesome and I do have other cars I could use on the track. However, I have just purchased another fibreglass car & the company that makes the bodies for them also owned a VX220 several years ago. Anyway, after much talk, he convinced me to keep it and 'revamp' it. A deal was done & I started looking around at what I'd like to do with it.
I don't want any more power, if I did, I would have bought the Harrop advertised on eBay recently and I think I have enough power now. So, my VX had to evolve or go. I've spent years treating it like a track slag, never caring about looks or damage. When it cracked, I used gaffa tape, when it got scratched I grinned, I really couldn't have cared any less for it.
After driving my GT3 RS now, it feels fast, comfortable & tidy. When I get out and look back at it, it looks nice and I like that. That's why I'm having a full overhaul of the bodywork, interior & mechanics. I ditched the rearview mirror after it fell off, ditched the rear lights after they got cracked, cut out everything that would save weight & binned everything I could from the interior including from the engine bay, lids, glass etc. some of that is going back on now!
The truth is, I'm getting old and it's time for some padding on the seat! Now the damn Porsche mileometer keeps telling me not to drive too far, replacement tyres & stone chips will wipe thousands from the resale price. So I've also learnt that I'm tight too!
I
I
I
I
I
I
V
Right, last photos of the car for a while....The daytime running lights look so cool on! When the bonnet & bumper is done, I will post again.
I like the old VX front bonnet edge relocated (in the photos it needs twisting down) bloody gaffa tape wouldn't hold it where I wanted it to go for long enough, but you'll get the idea.
#114
Posted 02 September 2018 - 05:49 PM
#115
Posted 03 September 2018 - 04:08 PM
#116
Posted 03 September 2018 - 05:52 PM
However, I will be adding weight back by beefing up the front radiator Shroud, which will be supporting the headlights and possibly a front lower frame, which will bolted to the crashbox, just in case I want to fit a manly plywood splitter at a later date. Overall though, I don't care if it's heavier, it will mean more cars to play with on track.
The daytime running lights alone are worth the extra weight.ðŸ˜Also the seat Leon door mirrors that will be electrically operated & folding.
....I just need heated seats, a good Audi system and pile carpets like Joe has.....Sorry, my mistake, it's piles that he has!
#117
Posted 03 September 2018 - 07:36 PM
i really wouldnt worry about weight bud
#118
Posted 03 September 2018 - 08:11 PM
#119
Posted 03 September 2018 - 08:12 PM
you need to go on a diet if youre that worried
#120
Posted 04 September 2018 - 06:26 AM
The airflow can be significant, ok not for cooling but the Lotus cup boys used the sills to feed an unofficial kind of ram air intake. It was so effective it was banned in their race series.
