Hel Full Length Sill Lines From Abs Unit
16 replies to this topic
#1 robin
robin
  • 3,810 posts
Posted 30 August 2018 - 08:00 PM
after waiting ages for some M12 fittings am now able to offer full length lines that run in the sills
from the abs unit to the rear brake line connects.
the line is covered in heat sleeve as per Hel lines specification for the sill section
and come unsleeved on from where front connection to abs unit
lines are in black but can be made to order in colour
price per set is £130 dilivered (same price as hel but with added length for free)
also available is abs to front lines and the usal four brake lines message if you have any questions
#2 robin
robin
  • 3,810 posts
Posted 08 November 2018 - 06:45 PM
Have a set made and available if anyone interested
Also have brake lines available for callipers
Two pot and four pot calipers.
#3 GeorgeBC
GeorgeBC
    Needs a cheaper hobby
  • 3,138 posts
Posted 09 November 2018 - 07:33 AM
I bought and fitted a set of these. My brake line had corroded where water gets into the sill from the turbo ear. Good quality product as expected from Hel. Once Robin had the correct size fittings communication and delivery was quick and painless. Worth doing for piece of mind or if your lines have failed. The cars are getting to an age now where corroded brake lines will become a common issue.
#4 Ivor
Ivor
  • 2,106 posts
  • Interests:Sheep & Ducatis
    and now bees
Posted 09 November 2018 - 12:12 PM
What I was thinking, but a post Xmas Thing for me if offer still on
#5 Nev
Posted 09 November 2018 - 12:26 PM
Important to fix the hyrdaulic lines down as much as possible with various fittings (like o-clips etc). Otherwise when you stomp on the brakes the lines will try to straighten, and if not fixed to the car well this will lead to a "soggy" initial bite to the brakes.
Edited by Nev, 09 November 2018 - 12:27 PM.
#6 Ivor
Ivor
  • 2,106 posts
    and now bees
Posted 09 November 2018 - 06:11 PM
How do you fix them in the sill, run them inside something else?
#7 robin
robin
  • 3,810 posts
Posted 10 November 2018 - 05:54 PM
i sugest to run them in electric conduite so wont move about is easy enough to do.
#8 robin
robin
  • 3,810 posts
Posted 16 February 2019 - 09:30 AM
Still available if anyone wants these or brake lines for vx or any car and bikes
#9 turbo boy
turbo boy
  • 1,161 posts
  • Interests:Cars, fitness, fishing, sports
Posted 22 March 2019 - 06:37 AM
Hi Robin,
I will take a full length set please 👍
Jon
#10 turbo boy
turbo boy
  • 1,161 posts
Posted 22 March 2019 - 01:46 PM
PM sent 👍
#11 robin
robin
  • 3,810 posts
Posted 13 May 2019 - 06:45 PM
have a pair of lines available to fit from abs unit to rear connection £130 delivered
#12 turbo boy
turbo boy
  • 1,161 posts
Posted 14 May 2019 - 05:30 AM
Hi Robin,
Sent you a PM way back for a full length set?
Please could you confirm?
Thanks,
Jon
#13 robin
robin
  • 3,810 posts
Posted 16 May 2019 - 04:35 PM
Have a set lines available
#14 tommobot
tommobot
  • 1,008 posts
Posted 22 May 2019 - 09:21 AM
I'm in the process of fitting a set..
What have people done for the routing of the hose through the dash to abs unit?
The original route looks near impossible to replicate 100%.
#15 robin
robin
  • 3,810 posts
Posted 24 May 2019 - 07:16 AM
you have to drill a bigger hole to feed it through dash area.
#16 robin
robin
  • 3,810 posts
Posted 24 May 2019 - 07:21 AM
http://www.vx220.org...hl= sill lines
worth a read was another post on forum but can find on fitting lines
#17 tommobot
tommobot
  • 1,008 posts
Posted 31 May 2019 - 10:55 PM
Would somebody be able to let me know which hose feeds on the abs unit lead to the rear calipers?
