Lightweight Aluminum Steering Arm Group Buy
steering arms ali bump steer
40 replies to this topic
#1 Matthew Bentley Racing Ltd
  • 774 posts
Posted 10 September 2018 - 03:41 PM
Hey All,
Got a group buy for you. Lightweight aluminium steering arms. New design vs the others available, comes with a stainless insert in the setting arm end to accept either the standard track rod end or straight bolt for rose joints (for bump steer adjustment)
- Lighter than standard
- Allows for more camber
- Comes with bolts
- Comes with steering arm insert for the option of standard track rod or rose joint
- Black anodised
Will retail at £99.95+vat
Group buy of 5 gets you them at £85+vat a pair
Group buy of 10 gets them at £72.50+vat a pair
Interest anyone?
#2 chris_uk
  • 10,060 posts
Posted 10 September 2018 - 05:06 PM
what aluminium grade are they made of?
#3 Sutol
Sutol
    Well it's nearly a Lotus
  • 8,121 posts
Posted 10 September 2018 - 06:41 PM
Interested.
#4 Exmantaa
Posted 10 September 2018 - 09:31 PM
Optimised for better bumpsteer? (So lower steering joint attachment than stock arm??)
#5 2-20
2-20
  • 1,316 posts
Posted 12 September 2018 - 09:04 AM
Good question...
I'd like to know as well...
#6 Matthew Bentley Racing Ltd
  • 774 posts
Posted 13 September 2018 - 01:10 PM
7075
#7 Matthew Bentley Racing Ltd
  • 774 posts
Posted 13 September 2018 - 01:12 PM
Half and half. The base ones for standard track rod end are standard geometry. Obviously when use a rose joint you have bump steer adjustability.
I could do some different inserts for those wanting to change the bumpsteer.
#8 Nikov
Nikov
  • 723 posts
Posted 13 September 2018 - 03:00 PM
Pics please.
#9 Matthew Bentley Racing Ltd
  • 774 posts
Posted 26 September 2018 - 04:34 PM
Before coating.
#10 siztenboots
  • 26,613 posts
Posted 26 September 2018 - 04:39 PM
if the trackrod vertical mounting point was 10% closer to the ball joint , then this would give same effect as a quick rack or would the bump steer be exagerated in a non linear way?
#11 Rosssco
Rosssco
  • 4,181 posts
Posted 27 September 2018 - 10:02 AM
How much extra for the rose joints (and covers) and inserts for adjusting bump steer?
#12 Steve.i.am
Steve.i.am
  • 990 posts
  • Interests:Bends
Posted 27 September 2018 - 10:45 AM
I'd be interested with the ability to alter dumpster with inserts.
#13 Vladimir
Vladimir
  • 111 posts
Posted 28 September 2018 - 12:34 PM
Are they the same as offered by Elise-parts?
https://www.elisepar...eering-arm-kit/
Edited by Vladimir, 28 September 2018 - 12:43 PM.
#14 chris_uk
  • 10,060 posts
Posted 28 September 2018 - 03:45 PM
Whats the deal with the long collets? Are they tapered? They look it but How far do they go into the arm?
Having them as they are now are you not just putting unnessecary strain on the joint between the bearing and arm? Considering you are constantly putting lateral forces onto that part directly, if you cant mount them lower (closer to the arm) would it not of been more sensible to make a more substansial spacer/collet in order to spread the load?
Is it possible to post more detailed pics where the tre or rose joint bolts into the arm unit.?
#15 fezzasus
Posted 29 September 2018 - 11:48 AM
I'm in if you get to the 10+ pricing
#16 larres
larres
  • 183 posts
Posted 30 September 2018 - 05:45 AM
I would take a pair also if we get 10+ buyers.
#17 fezzasus
Posted 30 September 2018 - 09:40 AM
1. Fezzasus (at 10+ target)
2. Larres (at 10+ target)
#18 haggi961
haggi961
    1cobrav8 is my god
  • 6,003 posts
Posted 30 September 2018 - 12:17 PM
Also interested at 10+
#19 2-20
2-20
  • 1,316 posts
Posted 30 September 2018 - 07:09 PM
Are the adjustable bumpsteer arms the same than non adjustable arms, with additional collets for rose joints ??
#20 2-20
2-20
  • 1,316 posts
Posted 30 September 2018 - 07:11 PM
Ok....
It's in the description...
Also tagged with one or more of these keywords: steering arms, ali, bump steer
