Track Day Air Intake Modification
crash box radiator cowl max
157 replies to this topic
#21 MAXR
MAXR
  • 2,719 posts
Posted 12 April 2020 - 09:28 AM
So this morning I walked into my garage, looked at the VX and hated the rear buttress. It’s out of proportion with the car, just too slab sided.
I’m going to redo it. But, I’m out of PVC, awaiting delivery. I’ll finish of the side intakes. Again, I don’t like the side pod shape either, so I’m going to change that too. I hope to get both sides finished today, before I need to cut the grass.
#22 MAXR
MAXR
  • 2,719 posts
Posted 12 April 2020 - 04:01 PM
Video update of modified door, front wing and engine air intake:
https://photos.app.g...p2WuTqBDxEHEnH8
#23 smiley
Posted 12 April 2020 - 04:49 PM
Did you run any numbers on how much air will flow through those bigger side flaps?
Reason is that i noticed my turbo vents are starting to come loose a little, and was wondering on how much pressure your enlarged ones may take at top speed.
#24 MAXR
MAXR
  • 2,719 posts
Posted 12 April 2020 - 05:26 PM
I’ve done no calculations. They barely stick out. But, because the door and rear panel curves inwards at the back, the opening looks big. I estimate that 70% of the air will flow through or around my oil cooler and up and over new wheel arches and exit directly out from the Vented rear. The main airflow has a straight through passage. The remains 30% of air I’m hoping will flow into the engine Bay Area to remove heat and again vent out of the rear.
The back of the car may look more Mclaren P1 style with large Black grill areas and lights fitted within the grills. My side pods will be bolted in place with captive nuts, same as the rear clam.
The truth is, it’s Probably just an unnecessary mod that will make the car worse! 😂
#25 smiley
Posted 12 April 2020 - 05:59 PM
Your airducts are in line with the aggressive lines of the total picture.
Now here is an example of an unnecessary mod :glare:
#26 MAXR
MAXR
  • 2,719 posts
Posted 12 April 2020 - 06:06 PM
That’s properly sh1t! 😂
#27 Foxy
Foxy
    I love Nev
  • 10,743 posts
Looks like something TVR Glen would advertise as mint
#28 MAXR
MAXR
  • 2,719 posts
Posted 13 April 2020 - 05:18 PM
A short video of revised changes made today to the coupe back and buttresses.
https://photos.app.g...g3Di5qqRLBMMoAA
#29 MAXR
MAXR
  • 2,719 posts
Posted 14 April 2020 - 03:59 PM
I spent the day trying to come up with a solution for the rear of my car. Well, I have decided in what I think works with the rest of the car. So I finally know what my car will eventually look like and can crack on once materials arrive.
I’m still unsure whether to fit a big rear wing or just leave it as it is.
https://photos.app.g...UZFtsHyKky8ubG7
#30 allsteel
allsteel
  • 445 posts
  • Interests:Winning lottery tickets,scantily clad women,real ale poured with a head,modified cars,great guitar playing.
Posted 14 April 2020 - 07:28 PM
I've been having a good stare at this and i'm not sure the big wing would work. The curvature at the back reminds me a bit of the MK2 Audi tt and i don't think the big one would work. Also reminds me a bit of the Europa but i cannot picture that in my head. Lee, up my way has just sold his and i'm sure his just had a smallish spoiler. Cannot beleive how quick you get the shapes knocked up. There's a lot waiting to see how this turns out but it's a helluva effort.
#31 MAXR
MAXR
  • 2,719 posts
Posted 15 April 2020 - 05:58 PM
I pulled the car out of the garage to take a proper look at it.
Overall, it looks good. But I think the rear end needs less of an overhang? So, I will be moving the rear bumper forward and also rotating it a little to reduce the slightly bulbous, awkward appearance.
I may try and fit a Boot lip spoiler like an M3 CSL or perhaps just make one up to fit.
https://photos.app.g...Rh4WHfBSpYYeSj9
#32 FLD
Posted 16 April 2020 - 12:02 PM
I really like how this is shaping up.  I was uncertain at first but it looks great.  For me, I would do a proper engine cover.  Whilst I like the reuse philosophy, there's so much effort gone in I'd love to see something awsomerer.
Top job Max
#33 myles
myles
    Sausagefest
  • 2,084 posts
Posted 16 April 2020 - 12:24 PM
Phenomenal work.
#34 MAXR
MAXR
  • 2,719 posts
Posted 16 April 2020 - 06:17 PM
Today’s update: PVC finally arrived midday. (7 days to deliver a next day delivery) Anyway, I cracked on And formed the front bonnet. It still needs fettling, but it’s tidy, clean and quick to do.
Any ideas on how to form a front grill surround to fit the front properly? The only idea I’ve come up with is to use a large profile door Foam seal and just fit that into the opening. Then I guess I’ll have to cover it in carbon fibre?
https://photos.app.g...yB6SLzr5VYcYzV8
#35 MAXR
MAXR
  • 2,719 posts
Posted 16 April 2020 - 06:26 PM
Top job Max
Well, I agree although I’m intending to reuse all the hinges, lock & opening mechanism (moved up obviously). It also increases the boot size! It looks more OEM in terms of It’s construction and is better resolved than those currently available (sorry just my opinion)
Just remember, my car is just a track car! It’s just a exterior update with cooling benefits: also, it was starting to look dated.
#36 smiley
Posted 16 April 2020 - 06:47 PM
The lights are giving away audi bases anyway, so that ship has sailed.
Why not use an aftermarket version grill without the rings in it, that already fits the contours of the bottom section.
That way you only have to find a way to connect the top section.
#37 MAXR
MAXR
  • 2,719 posts
Posted 16 April 2020 - 06:54 PM
Unfortunately, the bumper has been cut about Both in width & height before being patched back up & refitted. The Audi grill won’t fit and it’s also MASSIVE!
I’m probably not going to fit a front grill, maybe the lower ones, I’ll relook at meshes further down the line.
#38 MAXR
MAXR
  • 2,719 posts
Posted 18 April 2020 - 12:49 PM
Coupe back completed:
https://photos.app.g...XUErNFS8ZiRNBn6
#39 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 18 April 2020 - 02:54 PM
Very nice
#40 MAXR
MAXR
  • 2,719 posts
Posted 18 April 2020 - 03:40 PM
Thanks, it’s starting to look like a car again now, rather than the aftermath of a high speed accident.
I’m surprised how quickly the changes can be made and how relatively clean the whole process is (so far!)
Next will be the front Bumper bonnet and grill opening.
I’ve just purchased a set of Nissan GTR R35 rear lights which I am hoping to fit.
https://photos.app.g...Cc5zpNendtbRz36
Also tagged with one or more of these keywords: crash box, radiator cowl, max
