Has Anyone Used Tpms Tyre Pressure Monitoring System On Track Days?
Posted 06 December 2018 - 08:29 PM
I'm curious, has anyone used an aftermarket TPMS whilst out on track?
If so did it give accurate temps and pressures?
These come in 2 forms. One t replaced the valve and the sensor sits in the wheel and the other replaces the dust cap and they feed back to a display on the dash.
Thought it could be useful?
Sent from my LG-H815 using Tapatalk
Posted 07 December 2018 - 01:00 AM
I used to use the factory TPMS on my 2009 Cobalt SS to monitor when I needed to take air out after the tires got hot. The TPMS was surprisingly accurate and responsive, but I would only use it to know when to check with a real gauge and do tire temperatures. The Cobalt turbo was a fast, cheap track car I had here in Canada and it had a configurable display on the A pillar. I usually had the display set to tire pressures, g forces and kph. It could display a bunch of things, but this was usually most useful.
It was a good thing as it came built with the car. Personally I wouldn't invest in putting one in aftermarket as I would rather take tire temps across the tire surface. With the Speedster I just stop, check and have a feel for how the car responds on a track. The Speedster of course is a lot easier on tires than the Cobalt.
Posted 07 December 2018 - 01:21 AM
