Anyone With An Op-Com In The Hull Area
abs op-com
1 reply to this topic
#1 jdscott
jdscott
  • 51 posts
Posted 24 April 2019 - 11:41 AM
Afternoon,
ABS light has come on again and MOT due shortly.  I can usually find a break in a wire and fix it, but I have checked everything out and it all seems OK.  So, as per title anyone local with an Op-Com I could use to narrow it down?
Thanks
James
#2 swast4
swast4
  • 416 posts
  • Interests:Trackdays
Posted 24 April 2019 - 01:03 PM
Hi James,
I had real difficulty getting my traction control to work because of bad connections on abs module. I had continuity on all the cables on my meter but some of them wheren't good enough to carry current.
I really cleaned the connectors at the abs module, with electrical cleaner and a very small flat blade connector, then brake cleaner to dry out again.
Also try and check suspect cables with a, 12v bulb instead of multi meter, as this will prove that they carry current.
Adam
Sent from my LG-H815 using Tapatalk
Also tagged with one or more of these keywords: abs, op-com
