Posted 15 May 2019 - 08:29 AM
When starting, does anyone else have a starter that turns over really slowly for the first one or two revs before it goes fast enough to actually start the engine? Is this normal?
Gives me a bit of a scare as it sometimes goes so slow it kind of stops in between the first couple of revs..
Cheers,
Ian
Posted 15 May 2019 - 08:42 AM
Did you have a loo at your yellow starter relay in the boot for corrosion and to check if it is still snuck in place?
Posted 15 May 2019 - 06:34 PM
Foxy recently had the same issue, eventually resulting in a non starter, stranding the car at Zandvoort.
Root cause was starter motor wiring shorting on the gearbox.
Posted 15 May 2019 - 09:57 PM
Yellow relay should be fine but I’ll have another look. Had it all out a few years back when I had a no-start starter problem.
I’ll check the starter wiring, thanks. I’ve been down there recently and all looked ok on a cursory glance but I wasn’t looking for that specifically.
Posted 16 May 2019 - 11:17 AM
I would check the earth straps and battery clamps are good first.
But if it turns out to be the starter motor I have a brand new z22se OEM starter motor available if you need it.
Posted 20 May 2019 - 09:43 PM
Thanks Neil. I don't think it's the motor as it's done this with 2 separate motors (not new though).
I'll try those things first but may come back to you in the end. Ta.
Also tagged with one or more of these keywords: starter, problem, issue, slow
General Discussion →
VX220 Discussion →
Remove Canister And ProblemsStarted by simoambro97 , 16 Aug 2020 ![]() |
VX220 Discussion →
What Happens Next?Started by DX220 , 09 Jun 2020 ![]() |
VX220 Discussion →
Dbilas Turbo Kit - Z22SeStarted by Franke , 24 Feb 2020 ![]() |
VX220 Discussion →
Seat Belt Fixing ProblemStarted by ee601 , 24 Feb 2019 ![]() |
The Market Place →
Car Parts Wanted →
Little Silver Cap For Starter ButtonStarted by MattMacc123 , 19 Apr 2018 ![]() |
