Seatbelt Tensioner
seatbelt
7 replies to this topic
#1 Vladimir
Vladimir
  • 111 posts
Posted 07 June 2019 - 12:53 PM
Hi, I want to remove the original 3-point seatbelt since I’m fitting 4-point harness. And I noticed that the belt tensioner is connected with yellow cable, which is normally something to do with an airbag.
I wonder if I’ll get airbag error on dash if I will remove it and whether I should cut off the battery when I will disconnect it?
#2 Exmantaa
Posted 07 June 2019 - 02:12 PM
Put a resistor between the wire leads and all is fine. Do a search here, but from memory you need 2.8Ohm
#3 Aerodynamic
Aerodynamic
  • 1,455 posts
Posted 08 June 2019 - 04:48 PM
The yellow cable on the retractors are for pretensioning of the seatbelt while crashing.
Br, Per
#4 Vladimir
Vladimir
  • 111 posts
Posted 09 June 2019 - 08:46 PM
Br, Per
Yes, I was guessing the same. I am curios if disconnecting the cable will give airbag fault on dashboard?
#5 Exmantaa
Posted 09 June 2019 - 10:25 PM
Yes. As above, fit a resistor to mimic the belt tensioner...
#6 Vladimir
Vladimir
  • 111 posts
Posted 11 June 2019 - 07:39 AM
Thanks, will do. I'm in search for the correct one
#7 Vladimir
Vladimir
  • 111 posts
Posted 11 June 2019 - 08:01 AM
I'll leave it here for info to anyone
Passenger seat belt
Drivers seat belt
Steering column
2.7ohms (ref. to this topic http://www.vx220.org...om/?hl=resistor and this topic http://www.vx220.org...or#entry1951816 )
Edited by Vladimir, 11 June 2019 - 08:02 AM.
#8 Vladimir
Vladimir
  • 111 posts
Posted 11 June 2019 - 09:01 AM
While here it says 1.6 Ohms www.vx220.org.uk/forums/topic/142003-useddeployed-seat-belts/?hl=resistor#entry1853721
I’ll try 2.7 will write back which one is correct
Also tagged with one or more of these keywords: seatbelt
    Google (1)
