Both chains are included all guides tensioners etc, the only item not in the kit is the gasket, but I can arrange a genuine gasket if required at extra cost.
Note these are genuine chains.
The uprated mounting kit has top hats made from stainless and the much respected ARP bolts.
The mounting bolts have been known to fail occasionally, resulting in noise and possible chain failure. Hence the extra strength of these mountings.
I would need a minimum order of 10.
