Ok, it's been established that my ECU is broken. Apparently there is a separate earth within the ECU which has been damaged presumably due to the pinched O2 sensor wire. The car is perfectly drivable with the eml on but obviously this could cover up more important faults that could arise. I have the old CMS ECU which I could refit. The car is as it was with the CMS map except that I have uprated the injectors. Would it be ok to swop the ECU for the old CMS one?
#21
Posted 23 July 2019 - 05:28 PM
#22
Posted 23 July 2019 - 05:33 PM
Couldn’t BoT give you an idea?
#23
Posted 23 July 2019 - 06:36 PM
#24
Posted 23 July 2019 - 07:05 PM
personally i would rather go on the current ecu than blast round on a track with unknown fuelling.
#25
Posted 23 July 2019 - 07:39 PM
Peter does not live that far off spa. (150km)
Maybe ask him to reflash your map over your cms ecu on Saturday/Sunday?
#26
Posted 23 July 2019 - 08:59 PM
#27
Posted 18 September 2019 - 08:51 PM
BoT put 3 brand new sensors on over the
3 months that it has taken to track the fault. All 3 sensors were purchased from Eurocar parts and branded Bosch. As a last ditched attempt a vauxhall sensor was tried and hey presto no eml. Now it's early days and I'm half expecting the light to come on soon, but so far so good.
#28
Posted 18 September 2019 - 10:25 PM
Tempted to suck up the cost of a new genuine sensor and see what happens.
Car was fine when I first got it but it had a decatted VSE on it that was too noisy so I started to fiddle.
#29
Posted 18 September 2019 - 10:42 PM
i sell the NGK sensors pre = £75 and post = £95, they are the only ones i truly trust 100% to just work.
do you have a CAT? if not then you are going to get an eml.
Edited by chris_uk, 18 September 2019 - 10:42 PM.
#30
Posted 19 September 2019 - 11:39 AM
I’m wondering if the sports cat is right in the limit triggering the post cat error, but I even put the 2nd lambda in fresh air and it still came on.
Edited by jon_r, 19 September 2019 - 11:41 AM.
#31
Posted 19 September 2019 - 07:46 PM
Also tagged with one or more of these keywords: sensor, o2, fault
General Discussion →
VX220 Discussion →
Abs Fault - C0110 - Return Pump Locked Or ShortedStarted by Foxy , 25 Feb 2018 ![]() |
The Market Place →
Car Parts Wanted →
Cat Or Decat For N/a WantedStarted by Jason , 20 Jan 2018 ![]() |
Welcome to VX220.org.uk →
Guides and Tutorials →
Postcat Lambda Change Tutorial - P0140 - The Pictures EditionStarted by martinroger , 04 Feb 2017 ![]() |
The Market Place →
Car Parts For Sale →
A Few PartsStarted by tompooss , 20 Nov 2016 ![]() |
VX220 Discussion →
Help! Indicators Stuck On ConstantStarted by green_machineGC , 22 Jan 2016 ![]() |
