Europa Blue Turbo
51 replies to this topic
#21 coldel
coldel
  • 1,183 posts
Posted 08 June 2020 - 07:34 PM
Cheers. Got a few pics up now. Just ordered a Coolex Rad and new fan, should have that on as soon as the weather sorts itself out!
Also did the gearbox breather mod
#22 coldel
coldel
  • 1,183 posts
Posted 20 June 2020 - 06:56 PM
What a day. Took the car over to my Dads, my brother turned up also so we had three sets of hands for the job of changing the rad. Other stuff we had:
Coolex Radiator with new fan
Elise Parts rad hoses and new clips
Ten litres of Comma coolant
Full set of new fasteners for clam and rad surround
Type116 front tow post
Elise Parts rear tow eye
Shell Helix 5w40 and filter
MIshimoto magnetic sump plug
Replacement Bosch air filter
So a pretty penny spent.
We only managed to get half the stuff done thanks to two little bar steward allen bolts that hold the clam on to the door sill. Both rounded off due to being tightened at the factory by the Hulk. So had to dremel them and grip them to turn. Even then the retaining nuts just spun underneath. Spent about 90 minutes messing about with those two stupid bits of engineering. Without that we could have had the front clam off in no time.
Anyway it did come off in the end
So quickly put the Type116 front tow post in, took a little fitment as the holes in the post didnt line up with the shell but its in there now
Then we popped the rad shroud off and took out the old rad. The coolex was a perfect fit really impressed
Shiny new fasteners for the clam and shroud
And all back in place just in time for tea
The rad hoses that came off were in pretty good condition, the rad that came off (a plastic end OEM one) had a very minor leak in the corner, a touch of red dust present.
Very happy with the work done, even though it was a pain in the backside thanks to two little bolts.
#23 chris_uk
Posted 24 June 2020 - 10:11 PM
out of interest, which holes were the ones which didn't line up, if i need to change something in the jig it would be good to know.
#24 coldel
coldel
  • 1,183 posts
Posted 25 June 2020 - 06:52 AM
You mean the tow post? It was the ones at the top of the post they don’t line up with the existing holes so had to extend them to fit.
#25 chris_uk
Posted 25 June 2020 - 07:44 AM
The top centre one should of been ok, was it the angled holes on either side?
The crash box didn't have any holes holes on the angled part when i mocked it up so decided to move them slightly forward as to get a good surface area to grab, its a bit of a weird shape as its angled and then tapers backwards. As far as i can remember the vx one has the 1 hole at the too, the elise’s have 3.
#26 coldel
coldel
  • 1,183 posts
Posted 25 June 2020 - 07:59 AM
Sorry Chris didn’t put two and two together there! Yes when I took the clam off it already had three holes in the top. The two either side on the post were a bit further back than the holes so we ground back the holes in the shell to line up.
#27 mbes2
mbes2
    Someone say Plasti Dip?
  • 8,516 posts
    "Yes, I built it"
Posted 25 June 2020 - 03:40 PM
Maybe crashbox been replaced in its life with an elise one
#28 mbes2
mbes2
  • 8,516 posts
    "Yes, I built it"
Posted 25 June 2020 - 09:09 PM
Definitely not, mine is the same
#29 coldel
coldel
  • 1,183 posts
Posted 26 June 2020 - 04:11 PM
Sorry slightly confused, are you disagreeing with yourself?!
#30 2-20
2-20
  • 1,317 posts
Posted 28 June 2020 - 07:01 PM
Mine has 3 holes too and the crash box has never been replaced ...
#31 2-20
2-20
  • 1,317 posts
Posted 28 June 2020 - 07:14 PM
He means that his crash box is the same as yours.
So we are 3 with pre-drilled crash boxes
#32 coldel
coldel
  • 1,183 posts
Posted 06 July 2020 - 05:35 PM
Little job today, look after the windscreen with the trusty G5 and look after the headlights with some UV protection.
#33 coldel
coldel
  • 1,183 posts
Posted 02 August 2020 - 02:50 PM
So due to the extra time needed to do the rad last time around finally got around to doing the oil and air filter - pretty straight forwards, the exceptionally pretty Mishimoto Oil Plug was already in the car before I took this photo
This was sat just off to the side waiting to go on - ordered via Joe (aka The Batman on here)
Gorgeous gleaming new diffuser - great service from the guys getting it to me in less than 24 hours  :happy:  Anyway it offered up perfectly to the back of the car and makes it look so much better
#34 coldel
coldel
  • 1,183 posts
Posted 18 October 2020 - 01:46 PM
I had the windscreen surround wrapped in black but noticed now just how grey the dash is, its wrapped in an alcantara type material and with all the other black and blue going on it had to be sorted out. So took the dash out along with the binnacle and used some black suede dye and the results am very happy with!
Dash out and vents removed, took a fair bit of prep but cleaned it up and brushed the material in one direction
Used a sponge to dye the dash, brushing it in one direction before drying, then brushing it in the other direction
Then got it back in the car, was a bit of pita getting the screws in the brackets are in a ridiculous position through the cut outs in the dash but got there in the end
#35 Cavturbo
Cavturbo
  • 387 posts
Posted 18 October 2020 - 02:48 PM
Looking good. What tyres are you running and what do you think of them as its coming up to winter and I'm sizing up options. 400 bhp on cold roads...
#36 coldel
coldel
  • 1,183 posts
Posted 18 October 2020 - 05:27 PM
Mine is 225bhp I have Kumho on. To be honest I drove it around fine last winter but I live in London so we don’t really get the snow and ice other parts of the country get
#37 coldel
coldel
  • 1,183 posts
Posted 06 March 2021 - 06:18 PM
Thought I would update this page...
Resealed headlights, just bought some butyl tape £8 for a whole load of it off Amazon (seemed crazy spending £15 plus postage on Elise Parts its the same stuff) and did both front lights
Had the talented Ross Hogg Robinson retrim my steering wheel, I added a momo badge as well to the centre. I have a Momo Air gear knob too so it all matches up. Ross also supplied me with gear and handbrake gaiters same black with blue stitching - car looks new inside, its exactly how I wanted it
The gearbox breather mod I did, the ebay filter was going a little rusty so I picked up a plastic option and changed that over
Interior Mirror change! Fitting a smart car mirror with a minor bit of dremmeling, note that the mount for my mirror is a ball and socket mount that points directly down. Some earlier VXs may have a ball mount that is designed to go in to the back of mirrors not the top. Nice carbon gear stick cover! It feels brand new inside and is a pleasure to be in when driving!
Interior as I say is just lovely. Seats and door cards done in alcantara and leather. Steering wheel all done. Dashboard in black alcantara. Full Fred.org carpet set. New speakers and head unit. Momo gear knob. leather matching gaiters. chunky black handbrake. Extra alcantara layer for the roof. It feels brand new.
#38 swast4
swast4
  • 416 posts
  • Interests:Trackdays
Posted 06 March 2021 - 06:23 PM
Looks amazing, well done 😄
Sent from my F1 using Tapatalk
#39 Cavturbo
Cavturbo
  • 387 posts
Posted 07 March 2021 - 05:33 AM
Yes looks great. Love the slightly chunker steering wheel.
#40 hairy
hairy
    Moonlander
  • 6,028 posts
Posted 07 March 2021 - 09:38 AM
Very nice Mr Col!
