4 Channel Abs Unit
Posted 29 January 2020 - 01:31 PM
Sent from my Lenovo P2a42 using Tapatalk
Posted 29 January 2020 - 02:04 PM
Go to a lotus dealer, and take an S2 for a testdrive.
Then swap the abs ecu.
Lotus ows us for putting that piece of crap 2 channel in there in the first place.
Posted 29 January 2020 - 02:14 PM
Paul at Oakmere generally has them in stock. Should be £500-600
Posted 29 January 2020 - 02:45 PM
Posted 29 January 2020 - 02:47 PM
Posted 29 January 2020 - 02:48 PM
Sent Oakmere a message and will wait for a reply ðŸ‘ðŸ»
Best to call him IME !
Posted 29 January 2020 - 02:50 PM
Are the units plug and play or is there reprogramming needed?
Posted 29 January 2020 - 03:53 PM
You will need a lotus specialist reset with the ‘yellow cable’ to get it going, but it’s literally a 5 min job to fit it.
Posted 29 January 2020 - 04:11 PM
Now you've said it.
Posted 29 January 2020 - 05:29 PM
There’s one on eBay for £500
Posted 29 January 2020 - 06:29 PM
I'm the lucky one who normally pops up there so they can be programed on my car.
If you get it from Podge it will be ready to go so no messing about.
Posted 29 January 2020 - 06:32 PM
Posted 29 January 2020 - 06:37 PM
I have just been offered one ready to go off a VXR so I will try that and hopefully get some braking. I can't understand why Lotus are such a $h17 company and how it's legal to send a car out like that. The two channel ABS is by far worse than zero ABS
Probably as legit to blame Vauxhall as they are the ones who would have signed the car off
Posted 29 January 2020 - 06:48 PM
Posted 30 January 2020 - 08:38 PM
Who is Podge? He provides a plug and play version that requires no ECU work?
Posted 30 January 2020 - 08:55 PM
Podge is the very helpful parts manager at Oakmere Lotus. He’s run a group buy for these in the past.
He tries to supply the units programmed, but you need the unit to be fitted to a car to achieve this. On an Elise the module is a right PITA to get to, wheel arch liner off or maybe even a clam off job, on the VX it’s readily accessible. As I’m local and for a bit of back scratching, I’ve been over a number of times so they can be programmed on my car before they are sent to his customers.
Not entirely sure what they do with the mystical yellow lead but it seems to work!
Posted 31 January 2020 - 07:57 AM
Any Lotus dealer should be able to do it although my local needed a bit of pointing on what to do.
Posted 31 January 2020 - 07:59 AM
Litterally pointing them to the yellow lead helps to get a good start.
That is because it is an S1 lead, and does not make sense to use it when you are not in the know.
Posted 31 January 2020 - 09:20 AM
The 'job' with the yellow lead is simply to reset the unit which takes at most 5 min. The majority of that time is plugging in / turning on the car etc.
My car has been the slave to previous group buys too. It appears Foxy Jr and I are podges bitches.
Posted 31 January 2020 - 09:36 AM
Had a quick nose and two closest dealers to me (under 30 mins away) are Bell & Colvill Surrey and HR Owen in Acton. Presume both could plug their special yellow lead in? Presume B&C would be very knowledgable of this?
