Engine Cover
39 replies to this topic
#21 mbes2
mbes2
    Someone say Plasti Dip?
  • 8,515 posts
    "Yes, I built it"
Posted 22 February 2020 - 01:06 AM
I might an old one hidden away in my garage.
The heat build up with it fitted is noticeable so I removed it.
How long you had the vx? As I guess its lived this long without problems like many others.
Used to be a weighted engine boot mat thingy for sale on ebay, kinda good option if left outside or keep it in the garage/covered.
#22 mbes2
mbes2
  • 8,515 posts
    "Yes, I built it"
Edited by mbes2, 22 February 2020 - 01:07 AM.
#23 martinf
martinf
  • 129 posts
Posted 22 February 2020 - 07:12 AM
Hi, had my vx for only a couple of months. Been having problems with the immobiliser, think the error code was P1613 from memory so thought it might be corrosion in the Ecu connectors due to water.
Mine is an NA, bog standard. Is yours standard too, or modified?
I'm thinking of replacing the rad as it's the original and I've heard that they're not so good.
Cheers Martin
Sent from my LG-H990 using Tapatalk
#24 ICD
ICD
  • 101 posts
Posted 22 February 2020 - 05:43 PM
Some Bling showing my engine cover, its been on for 6 years, it does keep the engine surround "dryer", it does not cause any excessive heat increase, perhaps 1-2 degrees at most even in hot climates such as Greece.
They can be found in most scrapyards for a £5, seek and you will find.
As for a radiator upgrade, not necessary unless you are putting on more power imo. Many have lasted for over 20 years now
https://imgur.com/a/jpJH71m
Edited by ICD, 22 February 2020 - 05:47 PM.
#25 martinf
martinf
  • 129 posts
Posted 22 February 2020 - 05:56 PM
Thanks for your pics and info. I'm going to fit one to mine. I can't believe that Lotus/Vauxhall allowed the engine to be exposed to the elements like this.
#26 coldel
coldel
  • 1,183 posts
Posted 22 February 2020 - 08:44 PM
Of course they were designed to survive the rain, I think it would have been well documented otherwise of hundreds of Elises and Vauxhalls littering the roadsides of the UK each time it rains  :happy:  The turbos have a little metal cover on the inside of the mesh which covers the sparks, basically the water issue you *might* get is water in the sparks coils etc. by all accounts. You would be better served replicating that than completely sealing the heat dissipation, personally I have seen more issues with engines getting hot than getting wet.
Edited by coldel, 22 February 2020 - 08:50 PM.
#27 mbes2
mbes2
  • 8,515 posts
    "Yes, I built it"
Posted 25 February 2020 - 11:00 PM
Plus.. cover won't fit when you have a supercharger;-)
#28 martinf
martinf
  • 129 posts
Posted 26 February 2020 - 06:56 AM
That won't be an issue, it's staying OEM😀
#29 ayresyy
ayresyy
  • 489 posts
Posted 26 February 2020 - 08:00 AM
You have heard correctly. They can fail at any time, without warning. I was in the 'well it's lasted this long' clan until last year, half way down the A14 on route to Sliverstone, unannounced 90 Â°C antifreeze shower..    :ffs:
#30 coldel
coldel
  • 1,183 posts
Posted 26 February 2020 - 09:10 AM
A rad is on my list too - I'm still on the original one.
#31 mbes2
mbes2
  • 8,515 posts
    "Yes, I built it"
Posted 26 February 2020 - 11:47 PM
Bloody hell. I'm on my 4th lol
For the 5th spare waiting in the garage
Edited by mbes2, 26 February 2020 - 11:48 PM.
#32 coldel
coldel
  • 1,183 posts
Posted 27 February 2020 - 09:32 AM
I assume its the original, looks OEM, unless a previous owner swapped it out for an OEM one - but would have thought a nice aftermarket would be a better choice. My car has 68k miles on it, so not doing that much, I only did 2500 miles in it last year.
#33 quimbles
quimbles
  • 760 posts
Posted 27 February 2020 - 07:49 PM
70k OEM rad. Engine went first haha
#34 coldel
coldel
  • 1,183 posts
Posted 28 February 2020 - 09:44 AM
Haha you got me wondering now, I might have to trawl through the receipts (I have millions of them with the car) to see, it must have been replaced with an OEM one then, possibly?
#35 paul_mck
paul_mck
  • 284 posts
Posted 28 February 2020 - 09:46 AM
mine got to 93k on original rad
#36 coldel
coldel
  • 1,183 posts
Posted 15 March 2020 - 08:11 PM
This is mine, looks ok, I think!
#37 techieboy
Posted 15 March 2020 - 09:23 PM
It's the plastic end caps that let go catastrophically. Not sure there's any way to tell when/if it will happen.
#38 The Batman
Posted 15 March 2020 - 09:37 PM
my rad popped at 19k  on original rad!
#39 FLD
Posted 18 March 2020 - 09:20 AM
I have a turbo engine cover fitted to my na.  I now have a garage so would part with it.  If you're local to crewe collection would be very welcome as I really CBA with post.
#40 coldel
coldel
  • 1,183 posts
Posted 18 March 2020 - 11:08 AM
Turbo engine covers available for free in McDonalds if you can run fast enough
