Hi all, I'm a bit at sea trying to support my friend/neighbour with his VX220. We had an issue with an injector not firing which we traced to a faulty ECU. He recently received a new/refurbished ECU from:
https://www.ecutesti...nt/eem206274-c/
The ECU came reset
We have opcom software and I've attempted to program the ECU to the car (reprogramming of the ECU was reported successful), but wound up with a couple of fault codes:
P1615 Wrong Vehicle ID from Body Control Module
P1616 Wrong Vehicle ID from Instrument Cluster
The car cranks, but will not start
I attempted to reprogram both the immobilizer and the ECU together to see if this would resolve the fault, but the errors persisted.
I've had a good look search through the forums, and read the opcom guide, but I'm a bit lost and haven't come across this particular issue.
I have a feeling I'm doing something (probably very simple) wrong, but don't want to wind up making things worse. I'm located in NZ and the local dealership is no help as they don't have a clue what a VX220 is and don't appear to have the correct software to work with the vehicle according to my friend.
If someone could please provide me with the correct step by step procedure to code the ECU/Immobilizer to the vehicle or help with tracing this issue, that would be fantastic as I'm flying blind.
Edited by den7, 29 February 2020 - 05:09 AM.
