Stage 2.5 Turbo Exhaust
vx220 turbo exhaust stage 2 stage 2.5
13 replies to this topic
#1 simoambro97
simoambro97
  • 31 posts
Posted 23 April 2020 - 07:50 AM
Hi everyone, I'm going to do a 2.5 stage on my turbo vx220.
Upgrades done / to do:
- Bigger intercooler
- Direct intake
- Remove balancer shaft
- Spark plugs NGK a cooler grade
- Oil cooler
Now I would like to put a 3" decat direct exhaust and totally straight like the one in the picture.
What do you think?
Will it make so much noise?
Anyone have any videos?
Sorry for my english, i am helping with google translate
#2 simoambro97
simoambro97
  • 31 posts
Posted 25 April 2020 - 10:19 AM
up, anyone who can help me?
#3 techieboy
Posted 25 April 2020 - 10:46 AM
For what it's worth, I think it's a bad idea and will sound horrendous.
Whether there's any technical reason around back pressure not to, I've no idea on a turbo car. It certainly wouldn't pass any track noise limits in the UK and would fail an MOT so would mean the car wasn't street legal either but not sure whether either of those are an issue for you in Italy.
#4 siztenboots
Posted 26 April 2020 - 09:10 AM
vxr injectors, with ecu adjusted to new injector map
#5 chris_uk
Posted 26 April 2020 - 09:21 AM
i installed one on a customers car a couple years ago, didn't sound too bad actually.
if your looking for a tullett system let me know, i can also get you a balance delete kit if you haven't already got on.
Edited by chris_uk, 26 April 2020 - 09:22 AM.
#6 simoambro97
simoambro97
  • 31 posts
Posted 26 April 2020 - 02:20 PM
iniettori vxr, con ecu regolata sulla nuova mappa degli iniettori
I will have to do a good mapping, but are the injectors essential? how many hp do you think I could get?
#7 simoambro97
simoambro97
  • 31 posts
Posted 26 April 2020 - 02:22 PM
I would opt for the straight tube because it is certainly lighter and also less expensive, as regards the MOT in Italy it is not a real problem
#8 simoambro97
simoambro97
  • 31 posts
Posted 26 April 2020 - 03:35 PM
ne ho installato uno su un'auto dei clienti un paio di anni fa, in realtà non suonava male.
se stai cercando un sistema Tullett fammelo sapere, posso anche procurarti un kit per l'eliminazione del saldo se non sei già salito.
Thank you but I have already taken the removal kit
#9 hairy
hairy
    Moonlander
  • 6,028 posts
Posted 26 April 2020 - 04:13 PM
Don't you have an emissions test there?
#10 simoambro97
simoambro97
  • 31 posts
Posted 26 April 2020 - 04:23 PM
yes, but just go to the right mechanic  :groupjump:
#11 hairy
hairy
    Moonlander
  • 6,028 posts
Posted 26 April 2020 - 07:04 PM
Ahh - got it!
#12 scw02102
scw02102
  • 1,581 posts
Posted 04 May 2020 - 03:36 PM
Bigger injectors will help you going forward but are not essential at stage 2.
most people who fit a 3" exhaust use a Tullet. These are not loud and do allow track use.
Your biggest issue going past stage 2 is heat and a bigger intercooler wont help due to the location.
You have 2 options if you want more that stage 2, Meth or water injection. This will lower Inlet temps or you need a charge cooler.
80mm MAF is required if you go stage 4 but you will need a clutch, VXR turbo and injectors at this point, plus water injector or charger cooler.
Air filters dont really make more power. Max power on standard injectors is around 250bhp give or take.
Max power on a 2.5" exhaust is around 300bhp. The 3" version will allow a lot more.
#13 simoambro97
simoambro97
  • 31 posts
Posted 04 May 2020 - 04:47 PM
Thanks for the answer, for now I just need a stage 2 I would like the car to be reliable and I can't spend a lot, also because I have to take a nice set-up and I would like to put it a bit in place externally.
Anyway I bought the injectors, they arrived today   :D
P.S. I know almost nothing about meth and water injection, I will inquire. If you have any threads to recommend, I would be grateful.
Sorry again for my English, I hope you understand.
#14 scw02102
scw02102
  • 1,581 posts
Posted 06 May 2020 - 08:35 PM
I couldn’t tell you how to install meth or water injection but it has great results.
It halved my inlet temperatures and allowed more timing in the map to create more power.
Also tagged with one or more of these keywords: vx220, turbo, exhaust, stage 2, stage 2.5
