My Brilliant Yellow (Thanks For The Correction Guys!) Vx220 Turbo
youtube vx220 turbo
7 replies to this topic
#1 charliedrives
charliedrives
  • 8 posts
Posted 25 May 2020 - 07:54 PM
https://youtu.be/Yu_HzNWKaeQ
First proper drive in 8-9 weeks!! Here's my review of the new VX220 Turbo. 1f642.png
Edited by charliedrives, 25 May 2020 - 07:55 PM.
#2 smiley
Posted 25 May 2020 - 08:20 PM
Looking at your collection, i take it is the VX that is gonna see some track time soon?
#3 charliedrives
charliedrives
  • 8 posts
Posted 27 May 2020 - 10:24 AM
Absolutely :) Need to check on those engine mounts, get the battery fixed in position and do a full oil change.
I've heard disconnecting the ABS is also recommended!! :)
#4 smiley
Posted 27 May 2020 - 08:53 PM
Yes, abs cut off switch for the left front is advised.
Next to a gearbox breather pipe.
Check if you have the front tow eye, and if it actually fits (entry can get rusted)
Also advised to get a rear end tow eye mounted.
Fresh decent brake fluid strongly advised. Anything from the second section:
Then decent pads like rs14 or rc5+. If you are an aggressive driver, then use rc6.
Then once you get addicted, we will be happy to squeeze more investments out of you to take it to the next level.
Edited by smiley, 27 May 2020 - 09:00 PM.
#5 Pidgeon
Pidgeon
  • 5,254 posts
Posted 28 May 2020 - 07:36 AM
Can you do an executive summary?  Lost interest before anything happened.
#6 pete-r
pete-r
  • 2,771 posts
Posted 28 May 2020 - 05:11 PM
Can't wait to see part 2
#7 chris_uk
Posted 28 May 2020 - 05:47 PM
If you do need an engine mount or two, let me know :)
#8 WrightStuff
WrightStuff
    i am sheldon cooper
  • 2,238 posts
Posted 28 May 2020 - 07:15 PM
Please check your fuel lines in the engine bay.
They should be secured to the mount with fixings.
Often the fixings become brittle and snap with age, which leaves the joint prone to coming apart creating a fire risk.
http://www.vx220.org...cape-fuel-leak/
Also tagged with one or more of these keywords: youtube, vx220, turbo
