Ferodo Ds 3.12 Brake Pads
Posted 04 August 2020 - 11:21 PM
Cheers
Posted 05 August 2020 - 03:02 PM
Posted 05 August 2020 - 08:53 PM
What pads had you got before?
And what about the sound, are they noisy?
My car came with ds2500 on both axels
Posted 06 August 2020 - 04:00 PM
https://www.jdl-perf...2-fcp1562g.html
Rear
https://www.jdl-perf...2-fcp1560g.html
ds pads are not very noisy. nothing with carbone lorraine is noisy. the ferodo will sometimes make a slight squeak when you brake lightly. but not always.
I have ds2500 before ds1.11 And dsuno. Ds2500 is sh*t. they did not slow down in cold, and also poorly in heat. ds1.11 and dsuno are smashingly better.
Posted 06 August 2020 - 10:34 PM
And what about the bite? improved or hasn't a lot of bite
Posted 07 August 2020 - 04:02 AM
the bite is definitely better.
Edited by piwo, 07 August 2020 - 04:03 AM.
Posted 07 August 2020 - 05:21 AM
Front
Rear
Sorry but DS2500 stop from cold.
Posted 07 August 2020 - 01:39 PM
has a tremendous delay in braking response when cold
Edited by piwo, 07 August 2020 - 01:40 PM.
Posted 07 August 2020 - 01:59 PM
You can sort of understand pad behavior by looking at the friction rate table.
https://www.ferodora...ake-pads/ds2500
If it needs to go up in temp a little, it means they do not work optimal at cold bite.
If the line is flat from beginning, that translates in good cold bite.
The higher the friction rate, the more aggressive the pad. (When running in the optimal temp window)
Posted 07 August 2020 - 02:48 PM
it makes sense to compare the coefficient of friction for a given manufacturer and not between them, because each one measures as he pleases.
0,6u Carbone Lorraine that is not 0,6u ferrodo.
Edited by piwo, 07 August 2020 - 02:49 PM.
Posted 07 August 2020 - 10:33 PM
LC RC6 are good pads, but noisy and hasn't got too much care with the rotors
Posted 07 August 2020 - 10:40 PM
The specs of these 3.12 look good.
Just buy them and let us know what they do
Posted 08 August 2020 - 12:39 PM
No IT doesn't stop from cold. Ds2500 is sh*t.
I have them on the front and they work from cold.
They are similar to mintex 1144.
They are certainly not a good track pad but they work from cold and are better than a street pad while retaining low disc wear.
They don't have a high friction coefficient but still better than a street pad.
Posted 08 August 2020 - 01:49 PM
it was very interesting comparation. Always bloked rear. On cold And on hot on trackday And this config was fine. I don't like when front blocks And i like when block rear. Now i Has ds 1.11 rear And dsuno front and it's worse solution. Ds1.11 front DS3.11 rear could be better.
Edited by piwo, 08 August 2020 - 01:50 PM.
Posted 08 August 2020 - 02:59 PM
Posted 08 August 2020 - 03:27 PM
for now no problem with this.
friction is not surface dependent but strongly temperature dependent. it is better to brake a smaller tire surface, but not overheated at the edges from too small an angle
Edited by piwo, 08 August 2020 - 03:29 PM.
Posted 09 August 2020 - 08:52 PM
ðŸ˜ðŸ˜ðŸ˜ For the front axle surely I'll buy them. But the doub it's on the rear, ds1.11 or RC6
Posted 09 August 2020 - 09:12 PM
I had ds 2500 on front and ds 1.11 in rear And
I usually drive on open roads and traffic, block the rear isn't funny anyway...
I only found ds1.11 as top of the range for the rear brakes.
What you tell is very interesting, because on the rear you have worst calipers, traction force, more weight, I think less brake fluid pressure ... and you can block, so the pads has a good braking power or bite, I don't know if you block for the first instance or later. A good test, for me, will be fit rc6 on the back to see if happens the same and have more or less braking power/bite.
What tyres have you got?
Posted 10 August 2020 - 04:45 AM
225/45r17 avon zzr a64 rear and yoko a052 215/40r17 front
