for those who don't have the old facebook.
I've got in stock a couple sets of Spitfires new steering arm solution.
Giving the effects of a quick rack by an adjustable arm you can speed up or slow down the steering speed over standard.. along with bump steer reduction it also allows for and extra 4.5mm of extra front camber without the need to machine the hubs! The replacement track rod ends used on this kit are the same as the toe link bearings and its suggested that you can expect 10+ years per bearing.. thats pretty good if you ask me.
I'm doing them for £390 delivered per set.
