Lambda Cheater
17 replies to this topic
#1 apple2000
apple2000
  • 73 posts
Posted 25 May 2021 - 09:32 PM
any one ever sort the lambda cheater out to remove the engine light on the dash?
#2 ayresyy
ayresyy
  • 489 posts
Posted 26 May 2021 - 07:00 AM
  If you fit the cheater you shouldn't get any fault codes relating to the EGR system once the valve has been removed/blanked off. I believe you can still source cheaters from ebay.
#3 blackoctagon
blackoctagon
  • 195 posts
Posted 26 May 2021 - 03:37 PM
If it's a 2.2 I can tell you how to code it out in the ECU.
#4 ayresyy
ayresyy
  • 489 posts
Posted 26 May 2021 - 05:43 PM
A much better solution than fitting the cheater if you know the map addresses to be changed to switch of the EGR completely. It can just be left in place then for the visual MOT check.
#5 apple2000
apple2000
  • 73 posts
Posted 27 May 2021 - 07:30 AM
sounds like a plan, please tell me more
#6 C8RKH
C8RKH
  • 793 posts
Posted 27 May 2021 - 03:42 PM
And me!
#7 blackoctagon
blackoctagon
  • 195 posts
Posted 27 May 2021 - 05:28 PM
Certainly.
To begin with you'll need a £18 MPPS cable.
Then you'll be reading your ECU's .bin file.
Then you'll be using a hex editor to change a certain 1 to a 0.
Then you'll be reuploading the modified .bin to the ECU, having made sure you've used the new (probably automatic) checksum.
Still okay with this?
There a bit more to it, of course, but i've flashed my ECU many times including changing the idle speed map and the VE tables and you come to peace with it.
#8 C8RKH
C8RKH
  • 793 posts
Posted 27 May 2021 - 07:50 PM
Should be OK I was a S370 Assembler programmer for the early years of my 36 year career in IT lol...
Is this something that can be done with the OBDTuners software as I have that on my car?
#9 2-20
2-20
  • 1,317 posts
Posted 27 May 2021 - 08:06 PM
With OBDtuner you can easily disable the EGR.
#10 2-20
2-20
  • 1,317 posts
Double post
Edited by 2-20, 27 May 2021 - 08:09 PM.
#11 C8RKH
C8RKH
  • 793 posts
Posted 27 May 2021 - 08:40 PM
Thank you
#12 apple2000
apple2000
  • 73 posts
Posted 27 May 2021 - 09:07 PM
Certainly.
bit to tech for me that lol
#13 apple2000
apple2000
  • 73 posts
Posted 27 May 2021 - 09:35 PM
ive already got the egr blanked off, but now ive had the cat removed i want to get rid of the elm light
#14 smiley
Posted 28 May 2021 - 07:47 AM
I think 2-20 meant to say, is that obdtuner has the "disable cat check" option.
A bit expensive if you don't allready have it though.
#15 ayresyy
ayresyy
  • 489 posts
Posted 28 May 2021 - 07:48 AM
  If you are willing to share, I wouldn't mind knowing which address needs changing to what in the bin file for the EGR to be turned off. 😀
 I have tried to have a 'mess about' with GMPT E15 ECU and find some useful tables (wanted to lift the rev limit up), but as I think many have already discovered, it just doesn't play nice for amateurs like me.
#16 smiley
Posted 28 May 2021 - 07:56 AM
Slindy used to make some hardware cheaters.
You can read up on the technical side here.
http://www.vx220.org...-install-guide/
#17 techieboy
Posted 28 May 2021 - 09:24 AM
I'm still not sure whether we're actually talking about EGR Cheaters or O2/Lambda sensor cheaters.
If you're after an EGR cheater and you can't just re-position your original EGR valve, then how about https://www.ebay.co....BIAAOSwPn1dHElo
#18 Arno
Arno
  • 1,238 posts
Posted 31 May 2021 - 01:43 PM
Are people on this thread constantly mixing up (secondary) lambda cheaters/simulators (aka. cat-efficiency errors) and EGR cheaters/simulators? :huh:
Seem to be used through eachother, but ummm.. Kinda different :D
