Wich Wheel For 205/45 R17 Tires
5 replies to this topic
#1 Guest_Mengue (Guest)
Posted 31 May 2021 - 08:23 AM
Hi everyone, I'm new to the forum, I have an Opel Speedster 2.2 and I write from Italy.
The Bridgestone 175/55 R17 front tires are no longer found but I have the option to mount the 205/45 R17 (nothing else).
Of course it is not possible to use the original 5.5jx17 et26 wheel because it is too small. So I have to change the wheel and I was thinking of a 7jx17 (I have read many topics on this forum and I think it is the best choice).
My question is: which ET to prevent the tire rubbing and avoid the use of spacers not allowed here in Italy?
#2 Guest_Mengue (Guest)
Posted 03 June 2021 - 01:41 PM
can someone help me for the choice of the rims? Thanks!
#3 piwo
piwo
  • 174 posts
Posted 05 June 2021 - 08:59 AM
I have ats dtc 17x7,5 et20 with spacer 20mm (et0) AnD tires yoko a052 215/40r17. So 17x7 et10 with 205/45R17 should be Save.
#4 Saksaas
Saksaas
  • 1 posts
Posted 23 June 2021 - 09:32 PM
I run Protrack One. 17x7,5 et 20 front and 17x9 et 30 rear. 205/45 and 235/40 Hankook ventus v12 evo 2 tires.
Edited by Saksaas, 23 June 2021 - 09:33 PM.
#5 OneYet
OneYet
  • 1,354 posts
Posted 24 June 2021 - 02:50 PM
OEM rear rims will rub a little on full lock. I have a 3 mm spacer and then it is OK. Gives you an OEM look.
I also have the german ATS DTC that does not rub att all with 205 tires.
#6 Guest_Mengue (Guest)
Posted 25 June 2021 - 10:21 AM
thanks everyone for the info!
I think 17x7.5 ET20 or 17x7 ET25 is the best choice, I hope they will fit without rubbing
At the rear I can't change the wheel size, so I'll take 17x8
Edited by Mengue, 25 June 2021 - 10:21 AM.
