Vx Parts Clearout
14 replies to this topic
#1 DanGT
DanGT
  • 146 posts
  • Interests:Cycling, Silly plastic cars
Posted 27 July 2021 - 07:41 PM
Hi all,
Having a clear out and got some VX bits for sale I hope will be of use to someone. If anyone wants pictures give me a shout, offers accepted on all of it, all prices plus postage.
Eaton M62 supercharger, rotors need recoating £150
Front V grill, silver. ok condition. Can plastidip black for cost if required £30
S2 Exige S suspension, low miles £200
Lightweight plastic rocker cover Z22se £30
Exhaust manifold heatshield £5
Turbo alloys, good condition with decent but old tyres £150
Standard alternator £20
Z22se Inlet manifold £10
Z22se throttle body £20
Rear subframe brace bar (will need to drill subframe) £30
LSJ coolant pump bracket £5
LSJ 6 rib crank pulley £20
LSJ injectors £40
LSJ fuel rail/pipes £10
Original VX NA suspension, not leaking but tired. Good for MOT or temporary £25
K&N airfilter £5
If I find anymore bits i'll add them in
#2 abnvx220
abnvx220
  • 12 posts
Posted 27 July 2021 - 10:45 PM
Hi, I'd like to take the rear brace bar please if it's one which connects the rear tie-rod mounting points. Could you post pictures? Thanks, Robert
#3 abnvx220
abnvx220
  • 12 posts
Posted 27 July 2021 - 10:47 PM
Also interested in the Exige suspension if it will fit a vx220.
#4 abnvx220
abnvx220
  • 12 posts
#5 iain3915
iain3915
  • 269 posts
Posted 27 July 2021 - 11:32 PM
I've PM'd you about the front V grill.  Thanks
#6 oz2044
oz2044
  • 151 posts
Posted 28 July 2021 - 08:39 AM
Hi I'm interested in the NA tired suspension. Could you send me a couple of pics please? Thanks 😊
Sent from my SM-G998B using Tapatalk
#7 hairy
hairy
    Moonlander
  • 6,028 posts
Posted 28 July 2021 - 12:00 PM
Yes it will - I have one fitted.
#8 DanGT
DanGT
  • 146 posts
Posted 29 July 2021 - 07:45 AM
Thanks for the interest, emails coming to everyone who has messaged.
Dan
#9 DanGT
DanGT
  • 146 posts
Posted 29 July 2021 - 07:47 AM
I can send you pictures but its not one that connects to the inner toe links. It mounts inboard of them which would require drilling of the subframe. I bought it but never fitted it
#10 DanGT
DanGT
  • 146 posts
Posted 29 July 2021 - 07:50 AM
S2 Exige suspension fits the VX, the front ride height will be higher than standard however, so people use dropper brackets on the top damper mount to remedy this. I have a set available but they have been modified (welded and re-drilled) to give the car a lower ride height. I think it was 110mm but can't remember now
#11 abnvx220
abnvx220
  • 12 posts
Posted 29 July 2021 - 12:36 PM
Thanks for the replies. I was after a brace to strengthen the inner toe links and 110mm is too low for me so I'll leave both the brace and suspension.
#12 adamvx220
adamvx220
  • 598 posts
Posted 29 July 2021 - 02:13 PM
Hi mate pmd about 3 minutes after posted on forum but had no reply can you get back to me.
thanks Ad
#13 DanGT
DanGT
  • 146 posts
Posted 29 July 2021 - 05:13 PM
Replied
#14 blackoctagon
blackoctagon
  • 198 posts
Posted 30 July 2021 - 01:55 PM
I'd like the LSJ injectors, please.
[edit] PM'd
Edited by blackoctagon, 30 July 2021 - 01:57 PM.
#15 double r
double r
  • 64 posts
Posted 19 August 2021 - 01:37 PM
pm'd
