Bigger Brakes Up Front
34 replies to this topic
#1 F757lkk@gmail.com
F757lkk@gmail.com
  • 6 posts
Posted 31 July 2021 - 03:22 PM
Im probably going to fit Porsche 911 996 calipers to the front of the car. Does anyone have any links to bigger discs that will fit? I think the Alfa 159 330mm discs fit but need a spacer and spigot made to ensure proper fitting. Id rather something that bolts straight on. Any ideas? Any suggestions re the easiest fitting calipers too? I know the AP or lotus Exige fit but they come at a cost!
N1
#2 hairy
hairy
    Moonlander
  • 6,028 posts
Posted 31 July 2021 - 04:00 PM
Some pointers here: https://sites.google.../07---update-29
#3 Ivor
Ivor
  • 2,160 posts
  • Interests:Sheep & Ducatis
    and now bees
Posted 31 July 2021 - 04:01 PM
My experience with bigger discs, bought through this forum, they warped, 2 sets ...
#4 Ivor
Ivor
  • 2,160 posts
    and now bees
Have AP 4 pot calipers fitted
#5 oblomov
oblomov
    oblomov
  • 3,865 posts
  • Interests:Mumblers
Posted 01 August 2021 - 11:23 AM
Didn't Nev do something with Porsche calipers?
#6 Ivor
Ivor
  • 2,160 posts
    and now bees
Posted 01 August 2021 - 11:51 AM
Apparently a friend of Nev's did..
#7 F757lkk@gmail.com
F757lkk@gmail.com
  • 6 posts
Posted 02 August 2021 - 10:52 AM
Thanks for the replies chaps.
Hairy, thanks for that link. Do you know the fella that did that conversion?
#8 Exmantaa
Posted 02 August 2021 - 11:44 AM
Ps; WHY??
If you up the front, make sure the rears are beefed up too, as a standard VX is already front biassed...   :dry:
#9 F757lkk@gmail.com
F757lkk@gmail.com
  • 6 posts
Posted 02 August 2021 - 01:03 PM
I plan to move the std front calipers to the rear with RC6 pads to account for that.
Despite brand new RBF660 fluid, brand new RC6 pads, i boiled the fluid at Bedford a few days ago. I brake really late and hard. I done the same on my last track car.. The last being a Renaultsport megane R26. The only way i cured that was using Endless RF650 fluid with RC6 pads on the standard Brembo calipers.
Im off to Anglesea next month and dont want it to be a wasted trip so need to beef the brakes up.
#10 Exmantaa
Posted 02 August 2021 - 03:00 PM
Hmm, I have standard calli's with RC6E Front and RC6 Rear and RBF600. Did LOT Zandvoort 19/7 without issues (Harrop ~330HP), but maybe I'm still conservative and can brake a little later/more aggressive...
But I fitted some air ducting hoses through my fog lights!  (And the ABS turned off!!)
Do not know Bedford, maybe that one is really hard on brakes??
#11 Acidpopstar
Acidpopstar
  • 3,556 posts
Posted 02 August 2021 - 03:12 PM
Seems really weird boiling fluid with that fluid and pad combo. It could be something else going on.
I use RC6 pads and RBF600 fluid on standard calipers and have never come close to boiling it and never had brake fade. No cooling ducts fitted. Even at three tracks in south France in 30C + temps. Worked fine all day long. I don’t take it easy on the brakes either.
People have done race series with standard calipers and disks without issue. I’d do some more investigation before doing anything drastic.
#12 techieboy
Posted 02 August 2021 - 04:09 PM
^^ This
I've toasted brake fluid twice on track. Once when it turned out the offside rear caliper was binding slightly. The other, coincidentally at Bedford, was when using some shitty Yellowstuff brake pads that also managed to turn my front AP rotors blue from heat whilst barely managing to slow the car before effectively disintegrating. That turned out to be a problem with the size of the pads being slightly too large and dragging. Still got the replacement Yellowstuff pads EBC replaced them with in the pile of VX related sh!t that will never see the light of day again section of the garage.
#13 smiley
Posted 02 August 2021 - 04:44 PM
How long are your sessions?
#14 hairy
hairy
    Moonlander
  • 6,028 posts
Posted 02 August 2021 - 04:48 PM
Yes, Nev only lives a few miles away from me. He's still on the FB group.
#15 F757lkk@gmail.com
F757lkk@gmail.com
  • 6 posts
Posted 02 August 2021 - 05:18 PM
My session was around 15-20 mins. 7 or 8 laps maybe? After i let the fluid cool for an hour the car was fine but i didnt trust them so not great lap times
All pads seem to be ok and no dragging issues
I have mintex 1144 ( i think) at the rear. Maybe the RC6 fronts and the 1144 rear is a bad combo? However, i need the car to be spot on for the wales trackday
I need to replace the front towing eye bracket so clam need to come off. I will remove the spot lamps and duct towards the brakes
#16 Ivor
Ivor
  • 2,160 posts
    and now bees
Posted 02 August 2021 - 06:02 PM
Where abouts are you, I have duct kit I would part with as I'm never likely to fit it...
#17 F757lkk@gmail.com
F757lkk@gmail.com
  • 6 posts
Posted 02 August 2021 - 07:27 PM
Ivor, im Aylesbury, Bucks. Whats included in the duct kit?
#18 smiley
Posted 02 August 2021 - 07:53 PM
After i let the fluid cool for an hour the car was fine but i didnt trust them so not great lap times.
Best bring an easybleed and a spare bottle of brake fluid for such situations.
The air will be near the nipple, so a 30 min fix.
As for 1144 rear, with different pad behavior, i will leave it up to you as to why you did that.
Default bias is 70 front, 30 rear iirc. Some that want slightly less on rear use CL6E.
That has the same friction rate as the 1144, but at least you will be using sort of the same pads.
As for the 20 min sessions, i will queue in the line with the rest mentioning that that should be fine with the hardware you allready have. The duct kit is a nice bonus.
Edited by smiley, 02 August 2021 - 08:06 PM.
#19 Exmantaa
Posted 02 August 2021 - 08:15 PM
No no ,
The rear can use a bit more bias, so slightly less grippy RC6E fronts and normal RC6 rear.
(Only Eliseshop does not have the E’s anymore)
#20 Ivor
Ivor
  • 2,160 posts
    and now bees
Posted 02 August 2021 - 08:49 PM
Duct pipe and shrouds for the discs, I can dig it out and photo if interested, not sure how I'd get it to you in time though, you have to drill some holes iirc
