Hi all,
Wondering what the lowest temp the stack dash displays is supposed to be?
Mine displays 71C as its lowest, so direct from cold start up - is that correct? Seems to run at a VXish normal temp of between 88-91.
Cheers!
Posted 08 June 2024 - 10:37 AM
Hi all,
Cheers!
Posted 08 June 2024 - 02:13 PM
Posted 08 June 2024 - 09:20 PM
It's a weird setup. ECU sends the dash a 100Hz PWM signal to reflect temperature, min does seem to around 71-73degC.
Bizarre why they wouldn't make a dash that reads at all expected operating temperatures.
Posted 09 June 2024 - 08:18 AM
Mines about that, not sure exactly, but on my turbo it runs normally at 84 deg
My turbo is usually that as well
Posted 10 June 2024 - 02:20 AM
Agree!
Posted 10 June 2024 - 07:00 PM
82/84 deg.
