Cambelt Change
4 replies to this topic
#1 oblomov
oblomov
    oblomov
  • 3,845 posts
  • Interests:Mumblers
Posted 21 June 2024 - 12:55 PM
I did it myself before with the clam off, but need it doing now at short notice with the clam on.  I assume access is from below and above but my question is, is access  also (essential?) required from the rear offside wheel arch (can't actually picture it in my head).
The reason I ask is the charge cooler plumbing might be an issue if this is the case.  Just exploring options and potential problems because the time scale for fitting it in is tight and I don't want any issues.  Obviously a water pump change at the same time.
#2 hairy
hairy
    Moonlander
  • 5,979 posts
Posted 21 June 2024 - 01:36 PM
See Ronbots guide for sequence: http://www.vx220.org...-belt/?p=614724
I have a pdf with some of the pictures if you would like it.
#3 hairy
hairy
    Moonlander
  • 5,979 posts
Posted 21 June 2024 - 01:47 PM
aKra has posted some links for picture versions too: http://www.vx220.org...belt/?p=1993420
#4 oblomov
oblomov
    oblomov
  • 3,845 posts
Posted 21 June 2024 - 07:21 PM
Thanks, I did do a search and didn't find that.  Charge cooler pipework may therefore present a small problem with access.  Forewarned is forearmed. thumbsup  I'm planning a three week Eurotrip very shortly -France - Germany - Switzerland - Austria and Italy, and, the time since my last cambelt change started nagging on me so decided, with very short time left to have it changed, but no time to do it myself. This firm
https://www.reno-tech.co.uk/
although a Renault specialist is actually run by an ex Vauxhall guy.  Excellent no nonsense service. thumbsup
#5 joshua
joshua
  • 180 posts
Posted 22 June 2024 - 07:51 AM
Wheel arch liner definitely needs to come out otherwise I’ve changed mine a couple of times with everything else in place inc chargecooler hoses.
