2.4 Le9 With B207 Head: Which Headgasket?
Posted 08 August 2024 - 03:41 PM
Had a failure at snetterton the other night which ended proceedings early. Started as a misfire at 5500rpm and progressed to running on two exceptionally lean(pink exhaust tips) and very hot. Anyway starting with a coil pack replacement (wishful thinking) but mindful I may have to whip the head off to inspect things.
Does anybody know what head gasket I need for my LE9 block (2.4) running a B207 head? The LE9 is 88mm bore but I think the Z22Se block is 86mm bore.
Secondly, if anyone knows which head gasket I need, where can I get one from?
Jamie
Posted 08 August 2024 - 04:07 PM
Try pm ING blackoctogonHi guys,
Jamie
Posted 08 August 2024 - 04:19 PM
Posted 08 August 2024 - 05:37 PM
Likely just bog standard LE9 gasket would be it given bore size.
https://www.rockauto...ead gasket,5412
Posted 09 August 2024 - 10:58 AM
With standard z22se cams then just a LE9 gasket.
Posted 09 August 2024 - 01:36 PM
My old engine (a combination of a 2.4 LE9 (LE5) bottom end and modified Saab cylinder head) used this gasket p/n:
GM 12597769
Cylinder Head Gasket 2.4 LE5 12597769 (crateenginedepot.com)
Pretty sure it was sourced from Autovaux at the time
Edited by Rosssco, 09 August 2024 - 01:37 PM.
