New Member Speedster
Posted 06 October 2024 - 06:31 AM
im new to this Forum and bought an Opel Speedster Turbo from 2004 a few weeks ago.
I like the car very much but having some trouble with a boost related fault code that kills the fun on the car for me.
For this i write a new topic cause couldnt find any Solution by now.
Regards,
Speedsterturbo123
Posted 06 October 2024 - 08:14 AM
Welcome to .org
What is the error code?
Posted 06 October 2024 - 09:07 AM
I have a P1106-9 code which says malfunction in boost system.
I already have changed due to maintance and the problem (car was not used for a few years at orevious owner):
- both boost solenoids
- Mass Air Flow Meter
- Spark Plugs
- Ignition Coil Pack
- Map Sensor
- Engine Oil and Filter
- Both Motor Mounts
I also already tried to bypass the vacuum reservoir box what seemed to help a little with power from what i can say from a short test drive but still error code was stored a a little power loss after short drive was noticeable but no error lamp on dash just the fault in the ecu.
I also had the vacuum lines already smoke tested.
The only thing i saw that was a little confusing for me is that the wastegate actuator (which is boost engaged) has a lot of spring force on it and doesnt move that far on a still stand with full throttle (maybe 5-10mm).
I also regognized that i can hear the turbo spooling and letting boost go when i take my foot from the gas pedal.
Dont know if thats normal that i can hear it that clearly.
I also checked the membran from the DV Valve on the Turbo looked ok and was able to move with a hand vacuum pump.
At the moment i dont know what else could be the problem ????
Do you have any idea?
I hope that its ok to post here cause i dondt know what section is the correct one for that topic so please admins if its the false section please move it to the correct one - thanks very mich for your Help ????
Regards,
Speedsterturbo123
Posted 06 October 2024 - 09:08 AM
Regards Flo
Posted 06 October 2024 - 10:43 AM
Posted 06 October 2024 - 10:45 AM
Could be over boosting due to wastegate penny sticking or actuator would wound in too much and or check the arm is not fouling the vband
Also check earth continuity to boost solenoids
DG
Posted 06 October 2024 - 10:46 AM
Posted 06 October 2024 - 07:54 PM
Car accelerates bormal and has normal power but after few minutes you can fell that it has about 20percent less power.
Duncan VXR's PhotoDuncan VXR
Today, 10:45 AM
Hi Flo do you have a boost gauge/able to read boost levels with and without solenoid connected?
How far should the wastegate move on normal working vx220 turbo / speedater turbo?
It looks not bend and also does not touch anything in the area where the wastegate is.
How can i check earth continuity to boost solenoids does anyone has a wiring diagram or is it marked on solenoid what is earth cable?
I have oem intake what part do you refer to that collaps under boost?
Thank you very much for all the help!
Regards,
Flo
Posted 07 October 2024 - 04:56 AM
Posted 07 October 2024 - 04:59 AM
Posted 07 October 2024 - 06:43 AM
When the pipe is warm it can get pulled in so it is commonly replaced with a metal intake pipe.
Posted 07 October 2024 - 06:46 AM
You can find the wiring diagrams here: https://www.speedste...rams/index.html
Posted 07 October 2024 - 06:50 AM
Like this one: https://www.elisepar...bo-intake-pipe/
Posted 07 October 2024 - 11:54 AM
Ill check the ground points and look for an alloy intake then we will see if that fixes my problem - i hope thats the problem
Regards,
Flo
Posted 08 October 2024 - 09:26 AM
Good to hear it is not fouling and has travel and one less thing on the list. If the boost hose is not the cause
You really need to know static pressure it starts to open the wastegate with boost solenoid not connected to confirm it is set correctly. This will help rule out turbo wastegate and actuator function
Then what boost it is making with boost solenoid to before going further
Is the map standard on the car?
Posted 11 October 2024 - 08:16 PM
I was busy the last days but found time today to install an aluminium intake pipe but still after test drive i have the same fault code (no cel light) in the ecu.
It feels that its pulling a little bit stronger altough but maybe ots just imagination
Do you just unplug the solenoid for that test and if so its the one on the turbocharger - just for assurance what does the other solenoid refer to that sits at the intake manifold side?
For boost readings can i just read that trough obd on these cars or do you have to install an boost gauge?
From what i know and believe the car is standard map.
Thank you very much
Regards Flo
Posted 12 October 2024 - 01:02 PM
I tried today when i disconnect the solenoid on the turbocharger then i have almost no powet feels like half the power but im getting the same fault again after repluging and deleting fault codes it pulls strong but suddenly it reduces power little bit and the fault p1106-9 same as before shows up if i delete it or restart the car it has power as before like nothing wrong.
Posted 14 October 2024 - 06:38 PM
Posted 15 October 2024 - 05:51 AM
Unless the new parts you have fitted are fail on fit and everything piped correctly would be looking at what boost pressure it is making, a cheap guage and some silicon hose temp T into the system and sit in car to read....no need to permanently fit it in the car
It could be actuator, wastegate penny related and or turbo. But would see what boost it is making first before taking off car to check
Posted 17 October 2024 - 05:35 PM
I check if i can trigger the code eith unpluged boost solenoid.
At the moment i have tried another thing i put a map on the car and have the p1106-9 deactivated in the file for trial and made a short drive. Man that car is now flying in comparison and was not going into limp so far but i have another problem cause of the upper headshield on the engine/turbo that is missing on my car its getting really hot there and after the test drive where i put the pedal to the metal and accelerated often till 160kilometres for trial. I had a look on my turbo after that drive and the exhaust manifold on the turbo inlet was glowing red.
I winder if thats normal when the car is only mapped and nothing else changed that its getting that hot there or could that be a problem with my turbo?
Im not so experienced with turbochargers but just to be sure if thats normal with software only?
Do ylu or anybidy know where i can get that headshield cause at the local opel dealers here where i live they cant find it in their system?
Regards and thank you for your help (:
Im really enjoing the car even if its not that driveable at the moment like it should be (:
