Minimum Cold Cranking Amps
2 replies to this topic
#1 Bakazan
Bakazan
  • 231 posts
Posted 08 November 2024 - 07:36 AM
Does anyone know what the minimum cold cranking amps for the 2.2 is?
I'm thinking of getting one of those mini jump starters as a backup - but the claims of the size of the engines they can turn over seem ambitious.
#2 blackoctagon
blackoctagon
  • 191 posts
Posted 11 November 2024 - 11:09 PM
I don't know the numerical value you are looking for, but from my experience with a 2.2 diesel -remember they have much higher compression ratio than a z22se and are harder to turn over - if the car still has a battery thats not complete dead the packs will be okay for two or three starts.
I did consider, as part of weight reduction, replacing the normal battery with a tiny battery and two jump packs, with a switch between the packs to alternate them to allow charging but it all got too complicated.
#3 Bakazan
Bakazan
  • 231 posts
Posted 12 November 2024 - 09:11 PM
Thanks,  I went for one withe the spec:
Starting current 500A, Peak current 1000A (this doesn't make much sense to me)
Starts petrol engines up to 5 litres and diesel engines up to 2.5 litres.
I'll update whether it works should I need to use it.
