Safety Device Roll Cage Passenger Seat?
3 replies to this topic
#1 Steffen
Steffen
  • 286 posts
Posted 08 January 2025 - 07:10 AM
I've the Safety device rollcage mounted.
On the driver side I have a Corbeau race seat.
On the passenger side is still the original seat which is not a good solution, as for the belt as for the space for the head if the passenger is more than 170cm.
Does anyone have a tip for a seat that can be installed as low as possible...and also fits for the belts?
#2 hairy
hairy
    Moonlander
  • 6,028 posts
Posted 08 January 2025 - 08:17 AM
Not sure if these are still available: https://www.carlimit...roduct.php?p=41
#3 Steffen
Steffen
  • 286 posts
Posted 08 January 2025 - 08:39 AM
Sorry I was not clear anogh. Of course there are 4 point belts mounted for passenger, on the driver side 6 point.
It's a pure trackcar.
#4 Arno
Arno
  • 1,238 posts
Posted 09 January 2025 - 09:12 AM
Best bet is probably a Tillett, something like a B6: https://www.tillett....ats/b6-car-seat (also in FIA version if required)
Seat back is more reclined than the standard seats and combined with the low-mount brackets it should give the most headroom.
Actually you may want to ditch the Corbeau seat as well once you have sat in one of these.. :D
Steve Tillett actually has an Elise and races it too, so these are pretty much 'proven' designs. If you ever travel to the UK then you can usually make an appointment with them to go to the factory/showroom, and sit in various models.
