Filler Neck Ventilation Hose Connection Orientation
9 replies to this topic
#1 Attey
Attey
  • 4 posts
Posted 07 February 2025 - 06:15 PM
Hi,
I'm had my filler neck off my 2.2l VX220 and wonder which direction the ventilation connection should face when re-fitting. Before I removed the filler neck, the ventilation connection was positioned around 10 o'clock when looking from the right hand side of the car. However, the diagram shown in the link below shows it positioned around 6 o'clock (item 2 on the diagram). My car has a wide body kit on it so the filler neck will have been off before I bought the car and hence may have been re-fitted incorrectly.
https://opel.7zap.co...0|---fuel tank/
 assume the filler funnel should be fitted in the correct orientation to ensure the tank ventilation functions correctly when filling the car.
#2 stevieturbo
stevieturbo
  • 94 posts
Posted 07 February 2025 - 09:46 PM
6 o'clock would make more sense as it would also be to catch and drain any drips/spills on the way out.
If someone has moved it so much, how does the hose fit or has that been butchered too ?
#3 Attey
Attey
  • 4 posts
Posted 09 February 2025 - 08:53 AM
Thanks, that is what I thought.
I managed to look at another 2.2l yesterday which looked like the parts list drawing that I linked to in the original post (this had the breather at 6 o'clock). It looks like my filler neck has been significantly shortened (presumably to make it fit when the supercharger or body kit was fitted). The fuel pipes must have been changed at the same time to make the shorter filler fit, so I assume this error crept in at the same time.
#4 stevieturbo
stevieturbo
  • 94 posts
Posted 09 February 2025 - 10:06 AM
Fuel filler neck or design has no baring on a supercharger.
So if there is some odd bodykit, then that sounds likely someone may have messed it up then
#5 hairy
hairy
    Moonlander
  • 6,014 posts
Posted 10 February 2025 - 07:11 AM
Agreed
#6 hairy
hairy
    Moonlander
  • 6,014 posts
Posted 13 February 2025 - 02:51 PM
Don't worry about that Mussadiqhu, Trump and Musk will soon sort out all the problems in the USA.
#7 Ivor
Ivor
  • 2,123 posts
  • Interests:Sheep & Ducatis
    and now bees
Posted 13 February 2025 - 08:04 PM
Don't click the links on the text above
Edited by Ivor, 13 February 2025 - 08:04 PM.
#8 hairy
hairy
    Moonlander
  • 6,014 posts
Posted 14 February 2025 - 08:11 AM
#9 Ivor
Ivor
  • 2,123 posts
    and now bees
Posted 14 February 2025 - 11:22 AM
Mods removed the poster and posts
#10 hairy
hairy
    Moonlander
  • 6,014 posts
Posted 15 February 2025 - 08:21 AM
thumbsup
