Hi, Evening all. Hoping you can help me. I have a VX200 non turbo and starts and runs okay for 30mins. After 30min it cuts out and doesn't restart. Leave it to cool down for 15min and it will restart. It been like this for some time and been looking at different possibilities to what it can be. A few garages have has a look but no joy. I have replaced the crank shaft sensor but no joy. Plugged in a dynastic unit and doesn't have any codes. Is this a common problem or can anyone advise on what it can be. Is there any recommendation on where I could take it, located in north Kent. Thanks in advance. Brian.
Car Cutting Out After 30mins.
Posted 13 March 2025 - 07:39 PM
Posted 15 March 2025 - 11:20 PM
Back on Track nr Guildford
Posted 16 March 2025 - 06:02 AM
Posted 17 March 2025 - 03:37 PM
Check the fuel pump relay for heat, wiring and fuse.
And if its the pump, as noted above by Cavturbo, ánd it is heating up you could fill the tank to have more heat absorption capability from the petrol itself (petrol has a higher specific heat capacity vs. air-fuel vapour)and see if that lengthens the 30 minutes.
http://www.vx220.org...lacement-guide/ might help if it's the pump and you don't fancy dropping the tank.
Posted 17 March 2025 - 05:08 PM
Posted 19 March 2025 - 09:29 AM
thanks all, I can check relays but not sure where they are in boot ? is it the two behind header tank nearside rear wheel off. If its new pump that's out of my skill set. Can anyone recommend VX mechanic - garage in north kent area please thanks
Posted 19 March 2025 - 11:43 AM
Behind the carpet on the passenger side
Posted 19 March 2025 - 05:07 PM
Under a plastic coverBehind the carpet on the passenger side
