Wiper Motor
Posted 29 March 2025 - 06:22 AM
Posted 29 March 2025 - 06:23 AM
Posted 29 March 2025 - 06:40 AM
Posted 29 March 2025 - 07:08 AM
Posted 29 March 2025 - 07:09 AM
That didn't work<a href="https://www.imagebam.com/view/ME10NZ74" target="_blank"><img src="https://thumbs4.imag...ME10NZ74_t.jpg" alt="IMG_20250329_063748313_HDR.jpg"/></a>
Posted 29 March 2025 - 08:56 AM
Trying to post your image, the forum reports "You are not allowed to use that image extension on this community."
Old posts suggest a Citroen AX was the same....although that's probably just as hard to find these days.
The motor itself, many motors all look largely the same, same mounts etc. I haven't taken mine out of the VX as it works, but motors I've changed on my Corsa/Combo van years ago do look pretty identical.
Posted 29 March 2025 - 08:59 AM
I've uploaded to postimage to test if it works
Have you a photo of the wiring connector ?
do this, I've added lots of spaces to try and prevent it working so you can see the text. [ img ] https://i.postimg.cc...ME10-NZ74-o.jpg [ / img ]
Edited by stevieturbo, 29 March 2025 - 09:02 AM.
Posted 29 March 2025 - 09:02 AM
Great , thanksI've uploaded to postimage to test if it works
Posted 29 March 2025 - 09:03 AM
Posted 29 March 2025 - 09:44 AM
Also....what is failing ? Is it the motor itself, or the head that has some control over movement and positioning ?
If the motor, I'm sure you could probably swap the motor.
for reference then, just took mine. I thought I had an old Corsa one lying about, but can't find it. Only the linkage. Can't recall which way the motor faces, but I think it's to the right, and face down
Corsa for reference, similar vintage as the VX, although totally different connector, but still 5 pins and their mode of operation is pretty much the same as an old Corsa
https://www.ebay.co....tm/143159175015
Posted 29 March 2025 - 10:11 AM
Posted 29 March 2025 - 10:13 AM
Just wondering if I can take the motor rotor out of the cheap motor and put it in my VX one, might be the internal electronics that are damaged tho, will take them apart next weekAlso....what is failing ? Is it the motor itself, or the head that has some control over movement and positioning ?
Posted 29 March 2025 - 12:00 PM
Corsa
What is it actually doing ( or not doing ) ? Have you tried testing anything ? or applying power to the motor directly ?
Edited by stevieturbo, 29 March 2025 - 12:01 PM.
Posted 29 March 2025 - 12:19 PM
Corsa
Motor does not turn, definitely the motor as I've replaced it with a spare and it's fine now. So I've a broken one I'm ok with dismantling to see if I can get the new one from a different vehicle, different connector, to work
Posted 30 March 2025 - 10:01 AM
It's the motor that fails, damage from water ingress
It's all that welsh rain
Posted 31 March 2025 - 08:17 PM
Mine failed years ago from water ingress and I noticed a tear of the plastic below the windscreen through which water was running onto the wiper motor. I taped it up pending a more permanent repair, but it's still got the tape.
There should also be a plastic cover over the wiper motor.
Edited by KurtVerbose, 31 March 2025 - 08:22 PM.
Posted 01 April 2025 - 04:29 AM
The plastic cover is in place
Posted 13 April 2025 - 11:01 AM
Posted 16 April 2025 - 07:23 AM
Interested to see how you get on.
I've got the VW relay, but why not go the whole hog and fit a rain sensor?
They're < £15 from China.
https://vi.aliexpres...6101916941.html
