it is much lighter then the original manifold, pipes are wider in diameter, and the installation is a simple swap using the same 12 bolts or so.Ricky, I have noted that you have the Regal 4-1 exhaust manifold. Is totally different to the original? Pipe dimension? Layout?
The pipes seem to be quite short, in order to fit to the original exhaust. Have you noted a power increase? Noise?
cannot tell about power gains, since I installed it along with the komo-tec box, overall a big improvement above 4000 rpm, and the sound is growly-popping-tastic!!
