Edited by Ricky2772, 23 November 2004 - 02:58 PM.
Posted 23 November 2004 - 02:56 PM
Posted 23 November 2004 - 03:26 PM
Posted 23 November 2004 - 03:40 PM
Edited by garyk220, 23 November 2004 - 03:42 PM.
Posted 23 November 2004 - 03:47 PM
Presumably running wider tyres at the front would be a contributor to this? I wouldn't expect it to happen on a std VX running skinny 175s at the front.I oftentimes experience rears locking up before the fronts...
SorryWe just need someone who knows what they are talking about to help
Posted 23 November 2004 - 04:09 PM
Posted 23 November 2004 - 04:24 PM
Posted 23 November 2004 - 05:58 PM
Posted 23 November 2004 - 06:05 PM
Posted 23 November 2004 - 06:37 PM
Wouldn't using more grippy pads at the back increase the likelihood of rear lockup, instead of decreasing it?It's something ShinyAndy and Performance Braking are looking into though I believe, which is why he's running RS15's in the back with 14's at the front
Posted 23 November 2004 - 06:43 PM
Posted 24 November 2004 - 04:39 AM
You would have to think so. And the effect can be very temperature dependent if the pad characteristics change as they warm up.Wouldn't using more grippy pads at the back increase the likelihood of rear lockup, instead of decreasing it?
Posted 24 November 2004 - 08:18 AM
Posted 24 November 2004 - 08:21 AM
Posted 24 November 2004 - 08:22 AM
Drilling/grooving will probably reduce the efficiency of the brakes somewhat, due to the reduction of surface areaOtherwise, any other coatings/drillings/grooving are mere fashion and will not assist retardation. I paid £20 each for my discs.
There is unanimity RS14's are the best pad for the car. Try some before you try anything else.
They are that good.
Posted 24 November 2004 - 08:26 AM
Posted 24 November 2004 - 09:04 AM
Posted 24 November 2004 - 09:44 AM
Posted 24 November 2004 - 11:30 AM
What we need between us to sort this out properly is a hub / caliper with a big electric motor and 1/4 ton fly wheel then we could do some real controlled testing and getting numbers for different pads / different disks. I have never seen anyone using anything like this but it sounds highly desirable.
Posted 24 November 2004 - 11:45 AM
Posted 24 November 2004 - 11:53 AM
Fair enough, nobody disputes that it works well for you. But for those that are already having rear lockup problems, I don't think fitting grippier pads to the back as someone suggested is going to help them. Wouldn't you agree?and NO it doesn't make the rears lockup
