Front/rear Brake Distribution
#21
Posted 24 November 2004 - 12:28 PM
#22
Posted 24 November 2004 - 01:17 PM
#23
Posted 24 November 2004 - 02:32 PM
#24
Posted 24 November 2004 - 02:40 PM
That's fine if you plan to switch to Nitrons or something, but for those of us happy with the suspension why stiffen it up when a simple change of brake pad could do the trick?If dive is THE problem, then perhaps stiffening up the front is the way to go
FWIW though on my NA I've not had an issue with the rears locking up, it's always the front that triggers the ABS and to do that I've really got to be trying, even braking very late into the hairpin at Anglesey didn't trigger it very often.
#25
Posted 19 December 2004 - 06:30 PM
Edited by cyberman, 19 December 2004 - 06:49 PM.
#26
Posted 19 December 2004 - 06:46 PM
Ian,whilst I am checking out getting aluminium bell disks made
I'm still in the process of getting these sorted, as far as I'm aware the disks have been cast and the bells are being machined (of course Xmas is in the way so things will probably grind to a halt - pun intended
Let me know if you're interested in a set ?
#27
Posted 19 December 2004 - 06:54 PM
Oh, yes, probably. There seems no point in getting two lots made if the first is to scratch. I had missed any discussion of these. Do you have a spec? Grooved? Weight? Cost? Point me at where this is all set out?Let me know if you're interested in a set ?
I have been talking to Geary at Elise Parts and the one we have been discussing is based on the Elise Series 2 design they have. Same braking element just a different bell.
Regards - Ian
#28
Posted 19 December 2004 - 07:27 PM
#29
Posted 19 December 2004 - 07:37 PM
#30
Posted 19 December 2004 - 07:58 PM
I think it would be a very interesting experiment. It was my initial thought on the subject too. But like all things, sometimes its the "easy to do" rather than the best which happens.I am toying with the idea of going softer and fitting an adjustable roll bar that can be firmed up along with the dampers for track days. What do you think?
I don't think there currently is a rear roll bar (is there?) so how are you going to mount it? Making a front adjustable arrangement would be no trouble and IIRC Lotus have something suitable on the shelf (5 settings - probably of an Exige but I would need to check).
How soft were you thinking of making the springs? Taking them back to OEM would probably be too soft on pitch even though, as you would have the roll under control, it would not be quite so significant from a handling point of view. Steve was showing me some V expensive dampers the other day (£800 a corner) which have both high and low speed bleed settings. These might be good within this context for extra damping the essentially slow roll and pitch whilst leaving the high speed surface control intact. I'll talk to him about it this week.
I will also investigate what might be made / procured for remote ride control (ugh) as the idea of changing wheels each end of a track day and making multiple mechanical adjustments starts to take the gloss of things a bit. It starts to make buying a Radical and a trailer definitely more attractive.....
But if you were minded to make the experiment I'd be with you on that.
Ian
#31
Posted 19 December 2004 - 09:08 PM
Well things have come on. I have been looking at magnetic rheolytic dampers. I have .pdf file here to upload. BTW what is the official way to do this? It can't be right I have to upload them to my website and then crosslink, there must be a file repository on here somewhere. If someone can put me out of my misery of ignorance I'll upload it.I will also investigate what might be made / procured for remote ride control
Regards - ian
#32
Posted 20 December 2004 - 08:12 AM
#33
Posted 20 December 2004 - 01:34 PM
#34
Posted 20 December 2004 - 03:59 PM
PaulIan,
the tank is baffled.
Oh dear, then so am I, as I was definitely suffering fuel starvation until I filled up above half a tank. The problem only arose on the long straight following the big left hand corner down on the south circuit.
Those laps with no fuel starvation VMax 140+ indicated. With fuel starvation coughing and banging at about 100mph.
As it was only my first 4 laps or so I didn't have the problem (the alternator belt came off almost immediately after filling up) I rather hope to see 150+ next time out.
I wonder if there is anyway to make it more baffling (like get some foam into the tank) without cutting it open? I guess not but if anyone has done it it would be good to know. I suppose the other question is "has anyone else had the problem"?
Ian
#35
Posted 20 December 2004 - 04:21 PM
These here magneto-rheological dampers look very interesting. Basically a damper where the viscosity of the working fluid is directly controlled by a magnetic field. I think they are fitted to this years Corvette.I have been looking at magnetic rheolytic dampers.
The magnetic field is generated by an electric current (max 5A per damper). Its a DC effect with a response time of the order 2mSec (err, 1/500th of a second). Microprocessor controlled for semi-active suspension if you want it.
I haven't yet found enough hard tech stuff to decide whether they have the working viscosity range we would need but prima facie it looks like it. This seems a much better solution than a damper with two stacks of disks which can be alternately selected or sticking a motor on the side of a damper to wind it up and down.
I haven't found after market product yet but the company who holds the IPRs does do after market and is pushing into European car manufacture with it. I think it may be time to interest a specialist damper manufacturer in the topic if they haven't already noticed.
As to springs, I haven't yet decided if I like the idea of running a compressor in the car... It might be possible to do a two setting spring with an extra torsional spring in each corner that could be run clamped or free dependent on track or road use. However, this still leaves the ride height unaddressed and that seems the nastiest problem without the compressor. I'll continue looking / cogitating.
These guys had interesting product but not quite as we need it: www.varishock.com as do www.delphi.com (magneride).
Regards - ian
#36
Posted 20 December 2004 - 04:31 PM
Nope, where does it lurk? I don't actually know exactly what they are as Steve fitted and set them up when I wasn't present. However, if it isn't his trade secret, I'll find out and post it. I have a reasonable idea what they are.Have you seen the thread on spring rates?
I already do swap wheels each end of a track day and it's not that much of a pain really.
How do you get the wheels home? They can't possibly go in the boot and I don't really see them going where the blonde should be fitted.
Ian
#37
Posted 20 December 2004 - 09:23 PM
#38
Posted 20 December 2004 - 09:25 PM
#39
Posted 20 December 2004 - 10:03 PM
I refer you to the answer given above about springs. However, I have reason to believe that the rears are on 6 clicks. The fronts are definitely softer. I'll check and find out. Trouble is its not much use without knowing the spring rate.Ian, i would be interested to know what settings you have your nitrons on.
I actually think the rears pretty near spot on as long as you aren't driving on pave. Then the communication is quite direct... I am getting used to the set-up too.
Ian
#40
Posted 20 December 2004 - 10:08 PM
