Hitec Tuning Kit Supercharged
412 replies to this topic
#21 ChazUwe
ChazUwe
  • 2,450 posts
  • Interests:Cars, Computers, Drinking and travelling about.
Posted 04 December 2004 - 08:54 AM
Turbo ass whipping speed??!?!
#22 Whiteboy
Whiteboy
  • 6,950 posts
Posted 04 December 2004 - 12:55 PM
Along trip though if you live in England and supercharger breaks :o
#23 Robski
Robski
  • 1,905 posts
Posted 04 December 2004 - 12:59 PM
I believe Courtnay are in on it too!!! thumbsup
#24 WoodenDummy
WoodenDummy
  • 2,552 posts
Posted 04 December 2004 - 01:17 PM
A UK company is sorting fitting so we should be fine.
#25 BogBrush
BogBrush
  • 1,997 posts
Posted 04 December 2004 - 02:43 PM
The delta kit that courtney now product is £5500. I'd hope this kit would be cheaper than this? :unsure:
#26 TangoAlpha
TangoAlpha
    Mellita, domi adsum
  • 6,885 posts
  • Interests:Motorsport, Computers, American football, Photography
Posted 04 December 2004 - 02:50 PM
Hhmmmm the handling finesse for the NA, but also ridiculously fast! Sounds awesome.
Anyone know what the 0-60's might equate to?!?
If someone can let me know the torque figure then I can run it through my simulator.
#27 Whiteboy
Whiteboy
  • 6,950 posts
Posted 04 December 2004 - 03:21 PM
and courtenay are charging 7950 eu for their current suuupacharger :poke:
If you knew how much time (money) courtenays invested in the supercharger project, you would think that was very good value for money ;) thumbsup
#28 SPLAM
SPLAM
  • 6,491 posts
Posted 04 December 2004 - 03:56 PM
I thought it was the Delta kit that they fit. :unsure: If so, surely it can't of cost too much money to get set-up. :unsure:
#29 Whiteboy
Whiteboy
  • 6,950 posts
Posted 04 December 2004 - 04:05 PM
The supercharger was not the problem, it was the software to run it hence why it has a second ecu thumbsup
#30 #2177
#2177
  • 92 posts
Posted 04 December 2004 - 04:39 PM
HITEC is not using the Delta Kit, but a new setup, which uses many GM parts including a modified Eaton Blower. The art is 50% the mechanical setup and 50% the programming of the electronics. The delta kit uses the original plastic intake, while HITEC is using a new ALU intake, which provides the stability you need to support the blower. Depending on the requested power, HITEC changes the fuel injectors without adding anything or glueing anything to a plastic intake. All in all, very solid.. #2177 (Alexander)
#31 SPLAM
SPLAM
  • 6,491 posts
Posted 04 December 2004 - 05:00 PM
#2177 (Alexander)
Yep understood. thumbsup
I was just questioning what Whiteboy said about Courtneys time/money spent on setting up the Delta kit, but as he said, and you also stated, it is a lot to do with the electronics. thumbsup
Me now understand. :)
chinky chinky
Edit;
Anymore piccys or Video B) would be super. :poke:
Edited by SamH, 04 December 2004 - 05:02 PM.
#32 griffo
griffo
  • 227 posts
Posted 04 December 2004 - 05:26 PM
Is it just me or is someone somewhere taking the p*ss? You can order a complete, brand new, supercharged GM 2.2 crate engine (same as the n/a 220 plus supercharger) from the states for $3,660 (about £1,900). It puts out over 200bhp on lousy U.S. pump fuel with no mods. Even after freight etc to the UK that has to be the way to go. Griffo
#33 WoodenDummy
WoodenDummy
  • 2,552 posts
Posted 04 December 2004 - 05:31 PM
Gotta admit this have been going thought my mind, but I dunno if it fits right in.
#34 Flanners
Flanners
  • 441 posts
  • Interests:Into my cars, motorbikes and road bking
Posted 04 December 2004 - 06:28 PM
I'm starting to get very excited!
#35 clipping_point
clipping_point
  • 4,908 posts
Posted 04 December 2004 - 07:13 PM
Griffo
AFAIK they have not even started producing those engines. An advantage with the HITEC combo is the higher output and that the managment of the engine is solved.
The advantage of the crate engine is that u get a brand new product with a GM warranty. I´m not sure how the ECU questions will be solved with this one. :unsure: But it will prolly fit mechanically.
#36 vocky
Posted 04 December 2004 - 07:38 PM
Or you could by the super charger kit for @ $2500 from the USA, @ £1500 delivered to your door, designed by GM for the z2.2se engine. This is the offical GM super charger kit, sounds like the one being used by Hitec, probably :wacko:
Edited by vocky, 04 December 2004 - 07:42 PM.
#37 WoodenDummy
WoodenDummy
  • 2,552 posts
Posted 04 December 2004 - 07:44 PM
Yeah BUT will it fit? Designed for this engine, not designed for this car.
#38 vocky
Posted 04 December 2004 - 07:52 PM
Yes the mechanicals will fit (as it says in the first thread - mostly GM parts used), but comes with ecu remap that needs dealer to do - don't know if Tech2 can do it thou :unsure: . Was going to buy one, but my current car is a 2.2 vectra and the air con system would have to be removed completely :( and the bonnet slopes down over the intake :( , so chickened out of getting it. When I get my vx220 I will be fitting the GM sc kit :D
Edited by vocky, 04 December 2004 - 07:59 PM.
#39 WoodenDummy
WoodenDummy
  • 2,552 posts
Posted 04 December 2004 - 08:04 PM
I don't mean on the engine, I mean will it fit in the engine bay. Mid engine cars have all sorts of extra things you have to think about.
#40 #2177
#2177
  • 92 posts
Posted 04 December 2004 - 10:15 PM
Couple of points, the 2.0L SC crate engine mentioned before has a GM part number, but has not been shipped for 8 months. availability still open. On top of that it is just a 2.0L engine and HITEC wanted to provide superior performance to the standard turbo. the 2.2L SC Kit does not even have a GM part number and might never come to reality. HITEC is using parts from other engines of the L850 family, which had been launched in the States. I would say that approx. 20 additional small mods have to be done, on top of that the design of the pulley/belt configuration, the electronic program, the intercooler setup... Plenty of room for mistakes, if you do not have extended experience. I am still struggeling to understand, how they could some up with such a low price given the months of work, that they invested. #2177 (Alexander)
    Bing (1)
