Hitec Tuning Kit Supercharged
#81
Posted 08 January 2005 - 08:26 AM
#82
Posted 08 January 2005 - 09:28 AM
#83
Posted 08 January 2005 - 09:29 AM
If you want someone to put some miles on it just say the word!I'm starting to get allot of stick from Mark, friends and now customers ! about its lack of use, they may have a point 18months old and 1202 miles is a bit embarrassing
On the earlier post about reliability, I wouldn't be too bothered about shortened engine life provided the vehicle was reliable in the meantime.
#84
Posted 08 January 2005 - 10:02 AM
I'm conviced that this will be a very reliable conversion, as we (Hitec and ourselfs) had no internal engine problems with the old delta conversion and this was running without charge cooler etc. With the new conversion, the major componants i.e supercharger inlet manifold etc because off their OE use will have OE durability.On the earlier post about reliability, I wouldn't be too bothered about shortened engine life provided the vehicle was reliable in the meantime.
I for one cannot wait, I've got to give Marks turbo a run for its money...
#85
Posted 08 January 2005 - 10:38 AM
#86
Posted 08 January 2005 - 11:00 AM
Hi Steve its a good question as I want to work out the power to weight ratio. We should have this info very soon, we think at the moment its about 21 kilos. The drive shaft on the new unit is lighter as it is cast as part of the super charger housing.How much will the systems weigh? (v1 & v2)
Steve
In theory the stage 2 will be marginally lighter as the supercharger pulley is a smaller one (for more boost) machined from alloy, which may save .5 of a kilo, hey it all counts
#87
Posted 08 January 2005 - 11:07 AM
#88
Posted 08 January 2005 - 11:27 AM
#89
Posted 08 January 2005 - 11:38 AM
#90
Posted 08 January 2005 - 11:43 AM
Feeble excuse.I do have a little excuse, as it has no seats at the moment !!!!
As Foxy says MPG would be good to know.
#91
Posted 08 January 2005 - 12:04 PM
No this is not normal, as Maggs is getting much more than this. The problem we found on Damons was a weak recirk valve hose which was callapsing causing the manifold to get momentary boost on cruise. This meant that the computor would react but pulsing in fuel on the additional injectors and thus over fuelling the car at part throttleIIRC Damon was saying that he was getting under 15mpg following his SC conversion...is this what you would expect, Jon?
Therefore your cruise economy will be as standard. Full throttle will depend on how much you are enjoying yourself.
#92
Posted 08 January 2005 - 03:01 PM
Jon,what has hitec said about the head on the 2,2 engine?.
i know some of the engineers at saab, that is developing the turboengine aswell as the sc (not really official).
one of the biggest concernes for boosting a 2.2 is the weak combustionchambers in the head.
the roofs are too thin and the lostfoam-casting isn´t helping![]()
i got 2 (evolution3) cylinderheads from saab that has 80% thicker roofs and a upgraded kokill-casting.
they are good for >450hp and very stable at high cylinderpressures.
A little *bump* of Dudes question. Any ideas?
Oh also Will the rev limits still be the same?
#93
Posted 08 January 2005 - 08:21 PM
#94
Posted 08 January 2005 - 08:24 PM
And deservedly so to.Right I'm off for a beer
Thankyou Jon.
#95
Posted 09 January 2005 - 08:33 AM
we have dropped the compression far lower than GM for safety and durability.
How has the drop in compression been achieved Jon?
#96
Posted 09 January 2005 - 06:50 PM
I must be mad then...Most manfacturers will recognise what the police say in that even the most aggressive drivers can only drive flat out 10% of the time, before they come to an obstuction, be it other traffic, a junction etc.
just drove back home from ski-resort on my A6 on winters.........
it was an 1,5 hours long worth of 3-lanes hwy....
flat-out at 220kmh AT ALL TIME ...with few slow-downs in between...
wifey coud not believe I was home that fast...with her along, it takes usually 2+ hours.....
...aaaaaah..some fun here and there in life....
#97
Posted 10 January 2005 - 08:55 AM
The compression ratio has been lowered again by a lazer cut stainless steel plate and 2 gaskets. This seems to be a very commom way to do this, HKS do the same thing, we have been doing this on all our turbo conversion since 1988 in fact the more European tuners I talk to the more common it seems.we have dropped the compression far lower than GM for safety and durability.
#98
Posted 10 January 2005 - 05:16 PM
#99
Posted 11 January 2005 - 05:50 PM
Yes Sam, exactly that.So the plate is sandwiched between the two gaskets i take it?
#100
Posted 11 January 2005 - 06:29 PM
