Hitec Tuning Kit Supercharged
412 replies to this topic
#121 Ricky2772
Ricky2772
  • 3,685 posts
  • Interests:For those who grasp for Hir beyond the horizon of usual consciousness, preparing for the time when something powerful will present Hir-Self This advise is given...
Posted 16 January 2005 - 01:41 PM
Just one info,
the kit weighs 17-20 kg. That is nothing compared to other mods.
#2177
Alexander
that is the same weight of the delta kit, 20kg all included.
makes little if any difference, being right behind the cockpit...
#122 #2177
#2177
  • 92 posts
Posted 16 January 2005 - 05:41 PM
@Ricky: That is interesting as Hartmut( HITEC) gave me a much bigger number for the DELTA kit. Ok, such is life;-) :rolleyes: #2177 Alexander
Edited by #2177, 16 January 2005 - 05:42 PM.
#123 stevevx220
stevevx220
  • 1,138 posts
  • Interests:Cars, Photography, Computers. cars :)
Posted 16 January 2005 - 05:54 PM
:D :D :D Thats a suprise! :D :)
#124 Ricky2772
Ricky2772
  • 3,685 posts
Posted 16 January 2005 - 09:37 PM
if all tuners were to resort only to such small lies to push their sales, it would be a much better world!!! :D
#125 Jon
Jon
  • 183 posts
Posted 17 January 2005 - 01:25 PM
I was talking to Hartmut about the kit weights this morning. The new kit is 17.2 kilo's. Re the Delta kit he used the shipping weight as a base and Delta claimed this at 32 kilo's which did seem allot to him, however as I pointed out, this included all the exchange componants i.e the inlet manifold, 4 con rods and the adapted bottem pulley. I have a spare Delta kit in stock I will weigh it later without these bits and get back to you. thumbsup
#126 Ricky2772
Ricky2772
  • 3,685 posts
Posted 17 January 2005 - 01:35 PM
I placed the whole kit on the scale, all electrics included... it was a tad less than 20kg. obvioulsly conrods and manifold don't count, only the add-on parts..
Edited by Ricky2772, 17 January 2005 - 01:36 PM.
#127 Jon
Jon
  • 183 posts
Posted 17 January 2005 - 04:38 PM
Yes agreed, our delta kit weights this too. Just looking at the power to weight ratio a standard car with the new kit on weighs in at 892 kg at 235 bhp this would have a power to weight ratio of 263 per ton :D What does you car weigh now Ricky?
#128 #2177
#2177
  • 92 posts
Posted 17 January 2005 - 07:35 PM
Ah,
understand, the HITEC kit is 17kg including manifold and all other stuff, this is comparable to a 38kg Deltakit. Those two numbers are the weight of the incoming boxes at HITEC. So at least the HITEC kit is somewhat lighter.
Alexander
#129 Jon
Jon
  • 183 posts
Posted 21 January 2005 - 05:21 PM
Just to let you know I am over at Hitec on Monday to have a look at the finished article and to go out in it, will let you know how I get on. rallly
#130 SPLAM
SPLAM
  • 6,491 posts
Posted 21 January 2005 - 05:22 PM
thumbsup Look forward to your findings. :jump:
#131 Jon
Jon
  • 183 posts
Posted 21 January 2005 - 05:25 PM
Ok will do. I will get lots of pictures :D
#132 cheese-lobber
cheese-lobber
  • 26 posts
Posted 24 January 2005 - 09:50 AM
I'm excited about this, tell us more Jon. :groupjump:
#133 #2177
#2177
  • 92 posts
Posted 25 January 2005 - 09:48 AM
Just FYI, here is a diagramm, showing the enormous boost throughout all RPM areas. The only limiting thing is the rev limiter, it limits the HPS output now to 181kW ~ 245HPS. The drivability seems to be outstanding. Straight lines everywhere. Jon will be able to report on his experience. #2177 Alexander
#134 Ricky2772
Ricky2772
  • 3,685 posts
Posted 25 January 2005 - 11:59 AM
Alex, as per your request:
  • Attached File  dyno.jpg   61.58KB   0 downloads
#135 paulf-cam
paulf-cam
  • 1,186 posts
Posted 25 January 2005 - 08:22 PM
Hey there,
I'm a former lurker who has just gotten around to registering...
I've been following the hitec supercharger thread with interest and have overlaid the torque graph posted by #2177 over the only other torque graph i could find from a VXT:
>>link<<
On the pic below the red curve is for a std VXT with miltek + airbox and the thin black line is for stage2 courtenay tuning. The thick low res line is from the graph in this thread.
I've tried to match them up as good as i could, but there are probably slight errors :-)
(hope the picture works - this is my 1st post! ;-)
Cheers, Paul.
#136 paulf-cam
paulf-cam
  • 1,186 posts
Posted 25 January 2005 - 08:24 PM
...oh, and although the label says lb ft, really its in Nm, since i converted them. Yes I do have too much time on my hands :-)
#137 #2177
#2177
  • 92 posts
Posted 25 January 2005 - 09:43 PM
What you can see is that the chipped turbos have a higher torque, while the drivability of the sc is better as a result of the smooth curve. The power distribution is closer to that one of 3.5L NA. ANother important thing is that the torques does not drop of at 6000 revs, but is limited by the rev limiter in the 5th gear, in lower gears you can keeo the torque up to 6500. Without the rev limit even higher... Easy riding. I am eager to hear about Jon´s impressions. #2177
#138 paulf-cam
paulf-cam
  • 1,186 posts
Posted 25 January 2005 - 10:21 PM
Sure... And it looks like you've got a lot more torque down at 2000. What did the curve look like below 2000rpm? Cheers, Paul
#139 #2177
#2177
  • 92 posts
Posted 26 January 2005 - 06:42 AM
Although I have not seen it personally, I was told that it continues the trend to about 200Nm at 1500. #2177
#140 paulf-cam
paulf-cam
  • 1,186 posts
Posted 26 January 2005 - 01:22 PM
Nice. Hows the throttle response compared to the standard NA? I remember reading on this board that the VXT throttle response is a bit "soft", I guess thats due to the turbo. Not sure if the same applies to a supercharger? Cheers, Paul.
