Edited by cheese-lobber, 28 January 2005 - 10:37 AM.
Hitec Tuning Kit Supercharged
#161
Posted 28 January 2005 - 10:37 AM
#162
Posted 28 January 2005 - 11:22 AM
We have taken measurements, we are pretty sure it will fit the Vectra. We just need to confirm a couple more dimensions for the Astra 4 however we are hopefull.Is the conversion suitable for other Vauxhall 2.2 engined cars such as the Astra? or is this an exclusive to the VX220?
#163
Posted 29 January 2005 - 07:47 AM
#164
Posted 29 January 2005 - 09:33 AM
Hi Sam yes the conversions should be using the same ecu, so the upgrade should be the around the differance between the kits. However a sports exhaust (especially the front pipe with sports cat) will be required for the higher powered version.
This all sounds very
I know all prices aren't fully worked out yet but i was just wondering, if a customer (must start saving up) was to have the 230hp conversion upgraded (i just said upgraded) to the
BIG
one, would the cost be around the difference in the two guesstimated prices, or would it be a new management£
£ system or suchlike?
#165
Posted 29 January 2005 - 09:41 AM
We will keeps belts in stock, I have not had the exact price on the new heavier duty continetal belt, however typically a multi V belt is £17-20 pounds.Would the belts be easy to source &easy to fit, & how much would they cost?
#166
Posted 29 January 2005 - 09:45 AM
#167
Posted 29 January 2005 - 10:12 AM
Hi Steve, you don't have to have one, however the engine will accelerate quicker with one installed, I will be putting one in my car, as I love the way the engine feels & revs with the light one fitted.Jon
Do you recomend using a lightened flywheel with this supercharger?
Steve
#168
Posted 29 January 2005 - 01:06 PM
The girlfriend is telling me we need a new kitchen though, yeah right!
#169
Posted 29 January 2005 - 02:26 PM
#170
Posted 29 January 2005 - 03:30 PM
Alex will probably give us the first indications, the kit for my car is under way I should have this in the next few weeks, so hopefully in about 6 weeks I should have some figures.How soon do you think you'll be able to get some performance figs up? 0-60, 0-100, standing 1/4, 30-70 & some in gear would be great!
Doug
#171
Posted 29 January 2005 - 08:52 PM
#172
Posted 29 January 2005 - 09:40 PM
#173
Posted 29 January 2005 - 09:43 PM
#174
Posted 30 January 2005 - 09:20 AM
#175
Posted 30 January 2005 - 11:49 AM
#176
Posted 30 January 2005 - 01:04 PM
Edited by #2177, 30 January 2005 - 01:05 PM.
#177
Posted 30 January 2005 - 01:38 PM
THe SC can build boost levels up to 1 bar. wth the 0.72 bar , that is is used for this application it is far away from full load, the limiting factor here is the engine, which cannot take higher amounts easily without blowing away.
Do you know what the limiting factor is with the engine (i.e. the thing which would break at higher boot levels)? I seem to remember someone mentioning (i think it was dude) that the 2.2 has weak combustion chambers in the head...?
Cheers, Paul.
#178
Posted 30 January 2005 - 01:43 PM
#179
Posted 30 January 2005 - 01:44 PM
Mild mannered paulf-cam eats a banana and becomes...I am graph-boy, behold a new graph!
Graph-boy
Is it a bird? Is it a plane? No, it's Graph-Boy.
Excellent work Graph-Boy.
#180
Posted 30 January 2005 - 02:28 PM
I thought it had would break con rods first
I guess what I'm getting at is, whether the engine can be modded to take even more boost safely from the SC or if it would just be 'too' expensive...?
Bing (1)
