Rear Pad Replacement
#21
Posted 15 October 2003 - 01:35 PM
#22
Posted 15 October 2003 - 04:43 PM
#23
Posted 16 October 2003 - 06:38 AM
#24
Posted 18 February 2004 - 08:42 AM
#25
Posted 22 September 2004 - 07:00 PM
#26
Posted 22 September 2004 - 07:16 PM
Where is Martinh? - I miss his inane comments - did he really exist -did anyone ever see his Hotel in Brighton?Oh, forgot to mention...
Obviously, have the hand-brake released through all this!
Sorry, Ricky, I beat you to it, but there again you beat me to doing the front instructions!
#27
Posted 22 September 2004 - 07:21 PM
Where is Martinh? - I miss his inane comments - did he really exist -did anyone ever see his Hotel in Brighton?Quote Martin h - Why can't we have porn instead of pictures of brake pads
#28
Posted 22 September 2004 - 08:57 PM
#29
Posted 23 September 2004 - 11:30 AM
Steve states:
Fit the new pads, replace the pin and spring.
Tighten up the 17mm bolt fully.
Refit everything else, etc.
When I used to do this kind of thing many years back...(yeah yeah old git me) I always put a dab of some kind of thread lock (Loctite)? on the bolt to make sure it wouldn't come undone due to vibration... is this needed now or not? Just that as it's brakes better to be safe...... as it were
#30
Posted 23 September 2004 - 06:19 PM
#31
Posted 24 September 2004 - 08:40 AM
#32
Posted 04 December 2004 - 02:00 PM
#33
Posted 04 December 2004 - 02:21 PM
Try the bolt holding the caliper on an the bottom.I can't seem to hinge back the rear caliper as shown in picture 5.
All steps previous to this have gone okay - the outer brake pad is out and I can move the caliper side to side, just not backwards!
Help!
Thanks.
Paul
#34
Posted 04 December 2004 - 02:33 PM
#35
Posted 04 December 2004 - 03:45 PM
#36
Posted 04 December 2004 - 09:07 PM
Edited by Macca, 04 December 2004 - 09:08 PM.
#37
Posted 04 December 2004 - 10:28 PM
#38
Posted 05 December 2004 - 12:05 AM
If the garage managed to release the calliper then it should come off a bit easier at the next attempt. Sounds like you've had a bit of corrosion causing the lug/calliper to sieze together. When i did mine i used a pair of longnose pliers or circlip pliers. just opened them up so that i could insert the two prongs of the pliers into the holes in the piston body to turn it.Macc and Whiteboy - you have confirmed what need to do. However when you say 'tap' I thnk you actualy mean 'hit with a sledge-hammer'
Anyone know what size 'Piston retraction & turny tool' I need? I might invest in one to make the job easier!
I will have another go tomorrow!
Many thanks.
Paul
P.S. - 'Clarkson night' is on right now on UKTV People (channel 566)
Just a word of advice if you have ago yourself, I think that you have to turn the piston anti-clockwise on one side and clockwise on the other side of the car. I may be wrong (while since i changed mine) Can someone confirm this please?
Shame you dont live locally to me as i would have given you a hand to change them
#39
Posted 05 December 2004 - 10:50 AM
#40
Posted 05 December 2004 - 01:05 PM
Edited by Jase_MK, 05 December 2004 - 01:07 PM.
