Rear Pad Replacement
#41
Posted 05 December 2004 - 07:46 PM
#42
Posted 06 December 2004 - 02:59 AM
#43
Posted 26 December 2004 - 12:46 PM
DON't use WD40 (bad for the seals, may even contaminate brake fluid?) Instead use a silicon grease or spray.before going clockwise, pre-soak the piston with WD-40.
Edited by oblomov, 26 December 2004 - 12:49 PM.
#44
Posted 24 March 2005 - 09:07 AM
#45
Posted 22 August 2005 - 08:11 AM
#46
Posted 22 August 2005 - 11:06 AM
#47
Posted 11 December 2005 - 01:43 PM
#48
Posted 04 January 2006 - 05:58 PM
#49
Posted 04 January 2006 - 07:03 PM
#50
Posted 22 January 2006 - 02:42 PM
#51
Posted 11 June 2006 - 09:50 PM
#52
Posted 19 June 2006 - 06:49 PM
#53
Posted 19 June 2006 - 07:42 PM
Did my discs and pads all round today, rear ones would not pivot on the bottom bolt but I was able to remove the disc easily to get to the inboard pad. I was replacing the disc anyway but in future I will remove the disc to get access to the inboard pad.
I had this when first removing mine the steel boss that the bolt goes through sits in a chamfered recess in the hub, this can get stuck, i got it come free by wriggling backwards and forwards.
#54
Posted 07 January 2007 - 06:17 PM
It's when you've undone the 17mm bolt, tapped out the outer pad and the instructions say 'Lean the caliper back'. It's not quite as simple as that. This is a bit difficult to explain so I'm using a picture....
So the end of the barrel that the bolt runs through (Marked A) actually sits in a cup in the mounting (Marked B ) The caliper won't lean back until the two parts are seperated. The best way I've found to do this is to tap gently at the opposite end of the barrel using a wooden block, or something that won't slip and split the rubber boot. It doesn't take much force to seperate them but you have to do this before the caliper will tip back.
I hope that makes sense?!
Edited by benw, 07 January 2007 - 06:20 PM.
#55
Posted 08 January 2007 - 07:18 AM
#56
Posted 08 January 2007 - 02:32 PM
Nice one, Ben. Additions greatfully recieved!
Steve
Shame I didn't read the post immediately before mine though - which explains exactly what I was trying to in about a quarter of the words!! I included a picture though
Edited by benw, 08 January 2007 - 02:33 PM.
#57
Posted 17 January 2007 - 08:08 PM
#58
Posted 09 April 2007 - 06:07 PM
http://wiki.seloc.or..._Brembo_Caliper
#59
Posted 30 September 2007 - 07:55 PM
Edited by ukgulf, 30 September 2007 - 08:01 PM.
#60
Posted 30 September 2007 - 08:26 PM
