![:rolleyes:](http://www.vx220.org.uk/forums/public/style_emoticons/default/rolleyes.gif)
![Photo](http://www.vx220.org.uk/forums/uploads/av-2.jpg?_r=0)
Why Are They Called 'suicide Doors'?
Started by
Thorney
, Jan 15 2003 02:47 PM
4 replies to this topic
Posted 15 January 2003 - 02:47 PM
I assume cos if you open them whilst moving then you'd get pulled out by the wind - hence suicide but this could be complete bollocks
Does anyone know?
Posted 15 January 2003 - 03:12 PM
In theory, if you fall out of them while on the move, you'll get clobbered by the door on its way past.
At least with ordinary doors your clear once you are out!
Guest_Guest (Guest)
Posted 17 January 2003 - 10:26 PM
I think it has to do with there is usally no "B" pillar. Thus if the car gets hit on side impact you have little protection.
With the Maza however, the "B" pillar is built into the rear door and will take the impact as it should.
Mega
Guest_R1 NUR (Guest)
Posted 18 January 2003 - 06:47 PM
Car parked roadside. Std door: Whilst getting out passing car hits door. No problem
Suicide door: Whilst getting out passing car hits door. That hurts.
Posted 20 January 2003 - 08:40 AM
I seem to remember it's because with a normal front-hinged door, the wind blows the door shut. With suicide doors, the wind holds the door open, thus making it easier for people to jump out, ie. commit suicide!
Phill
