Posted 02 February 2005 - 07:31 AM
Posted 02 February 2005 - 07:32 AM
Posted 02 February 2005 - 07:34 AM
Posted 02 February 2005 - 07:35 AM
Posted 02 February 2005 - 07:37 AM
Posted 02 February 2005 - 07:42 AM
Posted 02 February 2005 - 08:14 AM
Posted 02 February 2005 - 08:16 AM
I thought technicallyI love you Europeans!
Posted 02 February 2005 - 08:34 AM
I used a 1,2mm cutting disk for stainless steel, mounted on a small grinder.1, how or what did you cut it open with
2, what did you weld it back together again with
3, did you use the same piece as you removed to cover the hole up
Posted 02 February 2005 - 08:54 AM
Posted 02 February 2005 - 10:28 AM
Posted 02 February 2005 - 10:39 AM
I have a MIG welder. But with a gap of 3 to 4mm to close up a TIG welder is a better choice.You can easily weld stainless with a MIG welder, use stainless wire and CO2/Argon mix gas.
Posted 02 February 2005 - 11:02 AM
Hi Pipo,Hi folks,
...I replaced the second probe by an electronic device so the EML-light doesn’t come on...
Posted 02 February 2005 - 12:03 PM
Posted 02 February 2005 - 12:44 PM
PipoI replaced the second probe by an electronic device so the EML-light doesn’t come on. Of course you have to keep a standard catsection in stock in case your car has to go to the annual checkup.
Posted 02 February 2005 - 01:00 PM
Posted 02 February 2005 - 01:12 PM
The second probe only checks the functioning of the maincat. If you leave the cat in place, then no need to do anything to the probe. I would remove the precat. It makes a huge difference to the engine, and it doen't make any difference for the MOT or the probes.
Edited by trescoman, 02 February 2005 - 01:18 PM.
Posted 02 February 2005 - 02:20 PM
Edited by walkes, 02 February 2005 - 02:20 PM.
Posted 02 February 2005 - 02:46 PM
That's why they make the first reflexionchamber the largest. It's important for engineperformance that the gasses can expand as much of possible when entering the silencer. It's a principle used in all reflexion sportsilencers. Of course the engine must have some backpressure to function well, because if there is not enough backpressure the gasses are leaving the cylinders so fast they can suck the new injected mixure with them. Thus creating a mixure which is to lean to be good. This happens during the time the inlet and outlet valves are open at the same time.hang on a minute is this not going to vastly reduce the pressure in section R1?
Posted 03 February 2005 - 08:09 AM
