Pre Cat Removal
49 replies to this topic
#21 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 30 January 2006 - 01:51 PM
Back in my pre-Milltek days I used one good 6mm HSS bit and a wood chisel to remove mine. Should have no effect on your MOT. AFAIK its primary function is to handle exhaust gases when the engine is cold.
#22 john_s
john_s
  • 1,801 posts
Posted 30 January 2006 - 01:54 PM
Yes... the pre-cat is only there for to meet EU requirements for emissions while the main cat gets up to temperature. As the MOT should be carried out on an engine up to temperature, the pre-cat isn't needed.
#23 JG
JG
  • 13,612 posts
Posted 30 January 2006 - 01:58 PM
i can't seem to get through the last bit of mine. Does the comb change on the other side? and does it go down the whole length of the 2 in pipe?
Edited by JamesGray, 30 January 2006 - 01:58 PM.
#24 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 30 January 2006 - 02:04 PM
As its a CAT you will find it will happily heat up and melt your bits, if your not careful. Drill as deep as you can without destorying the bit then use something like a wood chisel to remove the rest. It has the consistency of thick tin foil so once you get going its pretty easy to finish.
#25 VXT Tim
VXT Tim
    No it's not a Lamborghini!
  • 11,421 posts
Posted 30 January 2006 - 02:38 PM
So does the full milltek replace from the main cat back? Thanks thumbsup
#26 speedster
speedster
    Future of Speed
  • 3,600 posts
Posted 30 January 2006 - 02:50 PM
Full Milltek is everything, downpipe with no preCAT, Cell 200 CAT and backbox plus the whole system is Stainless Steel and weights alot less.
#27 VXT Tim
VXT Tim
  • 11,421 posts
Posted 30 January 2006 - 02:51 PM
I see, thanks for the education!!! thumbsup
#28 Richy
Richy
  • 8,699 posts
Posted 30 January 2006 - 09:42 PM
Has anyone tried burning one out with an acetylene burner :unsure: Ive never seen the inside of one fitted to the VX, anybody got a pic :unsure:
#29 jules_s
jules_s
  • 15,275 posts
  • Interests:Plane spotting
Posted 30 January 2006 - 09:51 PM
I'll have a look
Spoke to james earlier and there is deffo a PDF somewhere on here with pics of the pre-cat removal
thumbsup
#30 jules_s
jules_s
  • 15,275 posts
Posted 30 January 2006 - 09:57 PM
Ahah,
seems JG knows the powers of the 'search' after all
thumbsup
http://www.vx220.org...oads/precat.pdf
#31 JG
JG
  • 13,612 posts
Posted 31 January 2006 - 08:22 AM
thumbsup Mines all done now :D and what a difference it makes :D
#32 VXT Tim
VXT Tim
  • 11,421 posts
Posted 31 January 2006 - 08:24 AM
Think i'll save for a milltek, as soon as i'm nearing the amount, we need a new fridge or we need to book a holiday :angry:
#33 john_s
john_s
  • 1,801 posts
Posted 31 January 2006 - 01:20 PM
I'd hazard a guess that it wouldn't work. It certainly wouldn't work if the substrate of the cat is ceramic.
Plus there would be the danger of molten metal getting stuck to the sides of the downpipe or in the main cat...
#34 VXT Tim
VXT Tim
  • 11,421 posts
Posted 01 February 2006 - 10:38 AM
No to :flame: :D
#35 christurbo
christurbo
  • 3,784 posts
  • Interests:My Civic Type R
    My Black Beast of a VX!!!
Posted 01 February 2006 - 05:03 PM
Mine was already done when I bought it :P
#36 Winged Avenger
Winged Avenger
  • 121 posts
Posted 01 February 2006 - 05:08 PM
Is there an easy way to see of its been done without taking it to bits.
#37 christurbo
christurbo
  • 3,784 posts
Posted 01 February 2006 - 05:23 PM
Nope! Although I did notice a different exhaust tone [more of a burble] between other VX's I test drove! Plus I checked the previous owner's [blanchie] post on here saying how much of a biatch it was to get out! I think the only way to check properly is taking it apart.
#38 JohnyB
JohnyB
  • 667 posts
Posted 06 May 2006 - 05:27 PM
question .. why drill ? Cant you ram it out ? (i remember a post with pics when a member used a large hammer) Well i know you could but why is drilling better? Cause of the debris? I got my engine out and i thougt i might remove the pre-cat tomorow and would like to know if there's a short cut doing this with ramming it. :)
#39 JohnyB
JohnyB
  • 667 posts
Posted 06 May 2006 - 08:08 PM
Ehm went to my brother (where i have all the parts from my vx) and got the cat out in 10 min.
I just took it out..
I also then did the airbox mod - also simple as hell.
#40 christurbo
christurbo
  • 3,784 posts
Posted 06 May 2006 - 08:49 PM
Good work. thumbsup
Edited by christurbo, 06 May 2006 - 08:51 PM.
