Bonnet Release Problems
Posted 23 February 2005 - 01:07 PM
Posted 23 February 2005 - 01:18 PM
Posted 23 February 2005 - 01:25 PM
Posted 23 February 2005 - 01:29 PM
Posted 23 February 2005 - 01:36 PM
Posted 23 February 2005 - 01:44 PM
Posted 23 February 2005 - 01:47 PM
Posted 23 February 2005 - 02:20 PM
Posted 23 February 2005 - 03:16 PM
Edited by bAAx, 23 February 2005 - 03:18 PM.
Posted 23 February 2005 - 03:24 PM
Posted 23 February 2005 - 03:33 PM
Posted 23 February 2005 - 03:52 PM
Spot on, I had the same problem.Had this a couple of times after I removed the bonnet and refitted it slightly misaligned. Don't pull the lever too hard as they aren't very strong. Also, don't pull the bonnet up as this won't achieve anything if the catch is not releasing.
My advice would be to get someone to pull the lever whilst you try pulling/moving the bonnet in all 4 lateral directions (left, right, forwards, backwards). This should do it. Then grease up the catch nicely before you close it again. Best to use something that will stay like proper grease, rather than WD40 which will jus run away after a few hours.
Do the gaps all around the bonnet look even when it's shut? My guess is that the whole bonnet is slightly misaligned (pretty easy to fix).
Jase
It just needs to be wiggled in all four directions and a bit of force lifting the bonnet.
Posted 23 February 2005 - 04:42 PM
Front cover won't open...
Front cover - How to open (followup to the instructions/discussion in the above thread)
Posted 21 March 2005 - 10:58 PM
Posted 22 March 2005 - 06:42 AM
