Track User - Warning I
47 replies to this topic
#1 Marco Polo
Marco Polo
  • 268 posts
  • Interests:Cars and tracks :-)
    Roller skating in Paris
    Diving
    Wife and kids
Posted 27 February 2005 - 02:06 PM
A big advice for the track users around here (the problem may be less important for a "civil" use... rallly )
In the last months, I heard about the failure of the bolt holding the rear hub (including our friend Ricky I think)...
One of our member in the 1-11 Club in France had the same pb :
The broken bolts
The failure (on track, luckily he just did a 360° spin and slowly stop on the grass)
Here is the place (clean and no broken bolts), it is where the camber shins are located
So, when I revisited my brake setup (discs, pads and lines) I decided to check these bolts (and one of my friends asked one of his suppliers to supply stonger grade bolts) :
Bolts were pain in the *ss to remove, we understood after... they were just about to break !!!
And here is a more clear explanation of these bolts
So, my advice is to seriously check these bolts... They must be torqued to the right value so the mecanical stress is put on the contact zone (friction ?) between the hub and the carrier ball joint and NOT on the bolts themselves...
:unsure:
#2 Foxy
Foxy
    I love Nev
  • 10,743 posts
Posted 27 February 2005 - 02:29 PM
:o That looks well dodgy! You must have caught it just in time :rolleyes:
#3 cicastol
cicastol
  • 423 posts
Posted 27 February 2005 - 04:56 PM
I will put higher strength grade bolts!! ;)
#4 vocky
Posted 27 February 2005 - 05:28 PM
That is seriously worrying :o :o And there should be an immediate vauxhall recall, before someone dies.
Edited by vocky, 27 February 2005 - 05:31 PM.
#5 damontite
damontite
  • 177 posts
  • Interests:racing, racing, track days, more track days and sex. sadly not at the same time tho...
Posted 27 February 2005 - 05:48 PM
where can i get some of those strengthened bolts?? can you send me some please? i can send you some money of course... damon
#6 Marco Polo
Marco Polo
  • 268 posts
    Diving
    Wife and kids
Posted 27 February 2005 - 06:27 PM
Do not worry too much about these bolts... If they are torqued to the factory value, I think no danger can be expected (for a normal use)... However, for track use where stress is stronger, you should be very careful... And if you (or a poor Vauxhall/Opel dealer) touched these bolts (to alter camber settings for example), you should really check the torque value... As for the bolts I put (I have received a few PM), I'll ask my friend to give me more info. He is a mechanical engineer working at Renault and I am just a computer engineer ! :rolleyes: (and not working for Renault ! :lol: ) Further more, there is a point I remember (my friend talked to a chassis specialist in Renault about these bolts), these bolts should be changed if they are to be unscrewed (i.e always fit and torque new bolts if you work on them :beat: )
Edited by Marco Polo, 27 February 2005 - 06:28 PM.
#7 clipping_point
clipping_point
  • 4,908 posts
Posted 27 February 2005 - 06:47 PM
Are u using Yokos?? Puts A LOT more load on the suspension
#8 Marco Polo
Marco Polo
  • 268 posts
    Diving
    Wife and kids
Posted 27 February 2005 - 07:29 PM
Yep, I'm using Yoko 048...
#9 garyk220
garyk220
  • 3,035 posts
Posted 27 February 2005 - 08:25 PM
Good advice thumbsup I always replace bolts with new ones when working on suspension. Some of these are stretch bolts, and not worth taking the risk by re-using them.
Vauxhall had to ship hub carrier bolts from Germany for me because there were none in the UK. Suggesting they don't expect anyone to replace these bolts.
#10 Arno
Arno
  • 1,238 posts
Posted 28 February 2005 - 07:18 PM
Just an FYI, but as far as I know does Lotus supply grade 10.9 bolts (instead of the standard 8.8) for these parts when upgrading the S2 Elise to the LSS setup wit A048's and sport dampers. Going to 12.9 bolts may not be a good idea though. Although they are stronger under tension, they are more brittle, so do not resist bending/shearing forces as good. Bye, Arno.
#11 Foxy
Foxy
    I love Nev
  • 10,743 posts
Posted 04 March 2005 - 09:30 AM
Did anybody manage to get hold of the stronger bolts and does anybody know the torque setting? :unsure:
#12 garyk220
garyk220
  • 3,035 posts
Posted 04 March 2005 - 12:30 PM
45Nm according to TIS
#13 Saber
Saber
  • 108 posts
Posted 04 March 2005 - 10:59 PM
Hello,
Well, this is pretty worrying to say the least!!! :o Though it's probably just a case of not properly tightened screws.
Anyway, it shows that care must be taken when assembling such load carrying bolted joints - especially, it seems, when using the VX for track days in combination with high performance tires... These tires offer better grip (higher friction between tire and road), and this does when utilized as on track days and driving hard increase the loads on all components i.e. brakes, hubs, carriers, and chassis etc., BUT in this case the screws should (IMO) NOT experience any shear load, if the bolted joints have been designed and assembled properly.
I don't own a VX nor have I driven one - the Danish tax system does unfortunately not allow a whole lot of these cars on the streets - a new VXT/SpeedsterT costs approx. £ 65k with taxes :angry: . I admire the car though, wish I had one and reguarly read this forum, and since I am a mechanical engineer, I can give you some general and detailed guidelines on how to assemble what is commonly known as a "preloaded bolt joint" - like the ones used to connect the hub-carrier and the upper ball joint carrier. It definitely seems, that care should be taken. Some of you might already know what to do, and this "primer" might be a bit of a overkill, sometimes down to basics, technical and long, but I prefer to also explain the reasons WHY you should do things, the way I recommend, instead of ONLY telling you WHAT to do ;) Be warned...
The two screws from Marco Polo's car show clear signs of shearing, which means that the screws have stopped the hub-carrier and the upper ball joint carrier from relative sliding on a larger scale. This is probably no surprise, but it is NOT the way, that the sliding is meant to be prevented in this and most other cases!!! As Marco Polo says, the forces (from braking) are meant to be "transferred" (right word, I hope...?) from the hub carrier to (among others) the upper ball joint carrier as non-sliding, FRICTIONAL forces between the mating (contact) faces. You should therefore ensure, that there is sufficient friction between the contact faces, which basically means there sould be a COMBINATION of sufficient clamping force (pressure) and frictional coefficient between the mating faces. To be safe, I recommend ensuring that BOTH are as good as possible, as this "maximizes" the joints' friction load carrying abilities and best of all, it's a "non-fat strengthening" - no weight is added :)
To simplify, you should be aware of the following things:
1/ "Tightening torque, bolt pretension, clamping force, higher strength grade screws etc."
The reason you tighten these screws to a specified torque value is to ensure, that there is a sufficient, predetermined clamping force (pressure) between the joint's contact faces. Changing the screws to a higher strength grade does of course not automatically give you a higher clamping force (pressure) or resistance to sliding (which is what you actually want). So, naturally you also have to make sure that the tension in the screw is higher, which usually just means tightening the screw to a higher torque value (or sometimes, if possible, reduce tightening friction by lubricating threads and using the same tightening torque). Higher grade strength screws does of course offer greater resistance to plastic shearing and stretching, but this is as mentioned not the best way to deal with the problem at hand. The primary advantage of the higher strength grade screws would in this case be the possibility of higher clamping force and friction between the contact faces. Also the safety against separation of the clamped parts is increased, and believe it or not - the screws feel less of the external separating forces, the more the screws have been pretensioned/tightened.
However, caution is required when tightening the screws beyond the specified standard torque value, so that you don't strip the threads in the hub carrier !!. The threaded base material (hub carrier) MAY NOT have sufficient strength to withstand the higher screw tension, but if the material is ductile and a lot of threads are "engaged" (right word, I hope ?), it is usually not a problem. A bit of feel and common sense might be useful :P .
If replacing the screws to higher strength grade, I would suggest using strength grade 10.9 bolts, as Arno mentioned being used on the upgraded Lotus. But if the pretension in the bolts is not also increased at the same time, there isn't much point in using 10.9 bolts. I cannot specify a precise torque value, since I don't know the standard tightening torque value for the 8.8 bolts or for which assembly conditions it was specified (with or without washer, thread lubricant/anti-seize, what kind of lubricant etc.??). 10.9 bolts are usually tightened to a 35-50% higher torque value than 8.8 bolts. For example 10.9 bolts installed with a hardened washer and threads greased with molybdenum-disulphide have a recommended tightening of about 60 Nm (vs 44 Nm for 8.8 bolts)
IF I knew for a fact, that the material of the hub carrier was strong enough to handle the higher screw pretension, I would even recommend 12.9 bolts. The higher the clamping force - the better, 12.9 bolts would (all other things equal) give a 60 % higher friction load carrying ability over 8.8 bolts.
The difference between the brittleness of 10.9 vs 12.9 screws is quite small (the latter being neglectable (hope it's the right word...) more brittle), and if the screw is properly tightened, it is very unlikely, that it will ever fail during operation, so the brittleness should really not be concern.
It is as mentioned also good, common practice NOT to re-use screws, that have been tightened very close to or beyond the point of yielding (as with these) - use new screws whenever disassembling the joint.
2/ "Evenness of contact faces"
It is also important to ensure that the surfaces mate properly, which usually means that they have to be flat (no MACROscopical unevennesses) and not leave gaps that need to closed when being clamped together. This is done so that the preload in the screws is not "wasted" on closing gaps, because the elastic stresses in the clamped parts thereby reduce the pressure and hence the friction between the mating faces. However, I don't think, that this will be a problem in this particular case.
3/ "Condition af contact faces"
The four (or six, in case of using a camber shim) contact faces must also be THOROUGHLY cleaned before assembly. This means removing all rust, dirt, dust, oil etc. - basically anything that could otherwise contaminate the faces and potentially reduce the friction coefficient between the contact faces. This is an often overlooked way of ensuring a high friction coefficient - sometimes the friction can be doubled without to much trouble. Often sandblasting the mating faces is used to achieve a high surface roughness and friction coefficient. If corrosion of the contact faces is a problem, they can be painted with a very thin layer of an appropriate zinc-silicate paint.
So, to sum it all up, I would suggest using the following procedure when assembling the "hub carrier-upper ball joint carrier" joint (and a lot of other "critical" preloaded bolt joints):
1. Thoroughly clean all mating surfaces, using a steel brush to remove all rust, dirt etc. and using for example brake cleaner or some other appropriate degreaser to remove any oil, grease etc.
2. Assemble parts, fit and handtighten the screws. I would recommend using a hardened washer under the screw head, as this increases the precision in reaching the correct screw pretension when tightening. The washer also lowers tightening friction and greatly reduce surface pressure on the base material, which can help prevent the screw head from "settling" (plastic deformation of the base material under the screw head, which will reduce the clamping force), especially when using 10.9 or 12.9 bolts tightened to their respective correct tighening torque. Make sure that the screw with the washer installed is long enough, so that still at least approx. 20 mm of thread is engaged. Using a suitable grease ie. molybdenum-disulphide also lowers tightening friction and can increase the precision. Be careful not to get any grease on the mating faces.
3. Tighten the screw to the specified torque - preferably using a calibrated, good quality torque wrench - I assume it is approx. 45 Nm for 8.8 bolts and approx. 60 Nm for 10.9 bolts. Remember that the higher tightening torque of the 10.9 bolts also increases chances of stripping the threads in the hub carrier! Those of you familiar with DTI washers and angle tightening/torquing probably know what to do, though these methods might be a bit of a precision overkill :P
I hope this information is helpful and that I despite my somewhat "bad" english (I'm from Denmark) have expressed myself clearly enough - otherwise, please correct me if something is wrong or ask me if it's a bit unclear.
Further reading on bolted joints: http://home.jtan.com...KIAT/kiat_1.htm
Cheers ;-)
Martin
#14 cicastol
cicastol
  • 423 posts
Posted 05 March 2005 - 09:36 AM
Hello,
Cheers ;-)
Martin
Thanks very much for this essential info!!!
:groupjump: :groupjump:
#15 Marco Polo
Marco Polo
  • 268 posts
    Diving
    Wife and kids
Posted 05 March 2005 - 10:35 AM
thanks a lot Saber... chinky chinky You told us exactly what the Renault engineer told my friend (to resume : put stroner bolts and put more torque) but I was unable to fully explain it in english, no enough vocabulary... (would have been a different matter in computer or internet technology :tt: ) We used 10.9 bolts on the Front suspension and 12.9 on the Rear suspension, torque of 60 (he didn't not find 10.9 bolts in the right size for the Rear)... Saber, if you bass by Paris, give me a sign... ;)
#16 SPLAM
SPLAM
  • 6,491 posts
Posted 05 March 2005 - 11:50 AM
thumbsup Saber, very informative, 1st Post Gold medal coming your way. ;) Your English is very good. thumbsup chinky chinky
#17 Foxy
Foxy
    I love Nev
  • 10,743 posts
Posted 07 March 2005 - 04:41 PM
Imnotworthy @ Saber. Ta very much! chinky chinky
#18 Steve Crisp
Steve Crisp
  • 1,810 posts
  • Interests:VX220's...
Posted 07 March 2005 - 09:35 PM
Is it worth considering taking the bolts up a size? It would mean drilling out the old thread and tapping to a bigger size, but if there is plenty of "meat" there, then a larger diameter bolt would be a good move. Steve
#19 Ricky2772
Ricky2772
  • 3,685 posts
  • Interests:For those who grasp for Hir beyond the horizon of usual consciousness, preparing for the time when something powerful will present Hir-Self This advise is given...
Posted 08 March 2005 - 09:21 AM
I upgraded to 10,9-strength bolts long ago.... those 8.8 suckers snap at the mildest upset, and even if not broken immediately, will later on, like it happened to me... so every time you hit a kerb, I'd replace those two bolts just to be sure........ the mild 8.8 are very easy to strip off if overtighten or corroded...the female allen portion is quite weak, and will round away in no time if the allen key is sloppily applied.......and a TRUE bitch to remove then....heating up the whole hub with soldering machine, then hammering in a bigger allen key...nightmare... :sick:
#20 barrybethel
barrybethel
  • 1,112 posts
Posted 08 March 2005 - 05:43 PM
I have to say this post has scared the crap out of me. I've booked mine in for a service at Plans and they're going to check it all out. No track days until it's sorted!
