If you don't like them, I'm terribly sorry, if you do then I'm terribly happy!!
New harnesses + bullet cam
Rear vents location
mesh has been made flush to the bodywork
Pipe comes down to a point just before the heatshield
Scoop catches loads of air - small test before we put it on showed that
The scoop was initially made out of filler then a mould taken from it. It fits really well and behind it is a Demon Tweeks Nacar duct 3" pipe then goes down to the turbo area, No idea if it all works and when i can be arsed I'll put a temp guage in the bay and block everything I have done off, take a reading then unblock it and do another.
Customise Perfection did all the work in Southampton. If you want an air scoop I paid for all the development work and you are more than welcome to use the mould - no charge!!
Edited by geofflowe, 08 March 2005 - 01:22 PM.
