![Photo](http://www.vx220.org.uk/forums/public/style_images/master/profile/default_large.png)
Cel Light
Posted 17 March 2005 - 10:33 PM
Posted 18 March 2005 - 08:31 AM
![:D](http://www.vx220.org.uk/forums/public/style_emoticons/default/biggrin.png)
Posted 18 March 2005 - 09:45 AM
Posted 18 March 2005 - 11:36 AM
does it go off by itself after time (5 cycles) or do you have to reset it?I have the same problem. This because the EMS "Washes" the cat every 40 miles or so by running momentarily rich. It then compares readings from the Pre / Post Cat Lamda sensors and makes an OBD record.
The light comes on as "Low Cat Efficiency" - On mine this happens even with the exhaust CO's at 49 - compared to an MOT test top limit of 200.
The bottom line is that it's just an annoyance and the engine is running fine (and cleanly). My car has a 200 cell sports cat - this together with the precat and standard backbox mods was worth 8hp. The cat cost £170 - the rest was just time spent.
The risk of the light coming on is highest if the wash coincides with running at cruise power.
Maybe the answer is just to go flat out everywhere !.
#2177
Posted 18 March 2005 - 05:51 PM
Posted 18 March 2005 - 08:01 PM
Mine has never reset itself - I don't think it will, even after 5 cycles.does it go off by itself after time (5 cycles) or do you have to reset it?I have the same problem. This because the EMS "Washes" the cat every 40 miles or so by running momentarily rich. It then compares readings from the Pre / Post Cat Lamda sensors and makes an OBD record.
#2177
So far I have reset it (twice) with a Tech 2 (Vauxhall's service tool). Now I know it's nothing to worry about I've given up, might just remove the bulb.
The "proper" fix would be to increase the parameter used by the EMS to set the Pre / Post cat Lambda differential - someone need to work out how to do this.
I'm not particualrly keen on the Lambda decoy device - although they do apprear to stop the light coming on. The above fix would be better - and perserve the functionality designed into the EMS.
Posted 21 March 2005 - 08:34 AM
Weber Alpha - www.Webcon.co.ukWhat sort of cat have you got and where from?
Posted 08 April 2005 - 08:39 AM
Posted 11 April 2005 - 10:28 AM
Install a CEL light illiminator. See here: http://www.vx220.org...&hl=lambda&st=0What is the solution? I will get a system installed, which will close one of the two pipes unless I am in boost mode. This will also help to reduce noise during cruise mode.
#2177
It works fine for me and I have no cat at all.
Posted 15 June 2005 - 07:52 PM
![:o](http://www.vx220.org.uk/forums/public/style_emoticons/default/ohmy.png)
![:jump:](http://www.vx220.org.uk/forums/public/style_emoticons/default/jump3.gif)
![:groupjump:](http://www.vx220.org.uk/forums/public/style_emoticons/default/jump.gif)
![:blink:](http://www.vx220.org.uk/forums/public/style_emoticons/default/blink.png)
![B)](http://www.vx220.org.uk/forums/public/style_emoticons/default/cool.png)
![chinky chinky](http://www.vx220.org.uk/forums/public/style_emoticons/default/cheers.gif)
Edited by Ricky2772, 15 June 2005 - 08:00 PM.
Posted 15 June 2005 - 07:54 PM
Posted 15 June 2005 - 08:07 PM
I never understood it exactly...after Hitec mapped it , it was like that already, pulling stong anyway, dynoed at 217hp, but after few months the MIL light would come up here and there, sometimes the fan would kick in at start up...TBH Ricky it doens't sound like the car was mapped right in the first place.
![:unsure:](http://www.vx220.org.uk/forums/public/style_emoticons/default/unsure.png)
Posted 16 June 2005 - 07:29 AM
![:angry:](http://www.vx220.org.uk/forums/public/style_emoticons/default/mad.gif)
Posted 16 June 2005 - 07:41 AM
![:(](http://www.vx220.org.uk/forums/public/style_emoticons/default/sad.png)
Posted 16 June 2005 - 08:06 AM
Posted 16 June 2005 - 10:16 AM
+12V heater is the outside white if i remember well!!. With one of the white is +12v? the outside one or that next to black signal??
P.S. to clear the things i will make some photo of my working connections
![;)](http://www.vx220.org.uk/forums/public/style_emoticons/default/wink.png)
Edited by cicastol, 16 June 2005 - 10:17 AM.
Posted 16 June 2005 - 05:00 PM
no!! I made that mistake yesterday...the first white in line is the ground, so leave it alone.... the heather is the second white.... once that was hooked up, the green led started to blink...+12V heater is the outside white if i remember well!!
Posted 16 June 2005 - 08:15 PM
Posted 18 June 2005 - 04:13 PM
Posted 19 June 2005 - 04:27 AM
![thumbsup](http://www.vx220.org.uk/forums/public/style_emoticons/default/thumbsupgraemlin.gif)
