Located the lambda socket in the engine bay and unplugged it. Taken near side rear wheel off and loosened the wheel arch plastic and pulled back and then pulled the lambda socket through:
![Posted Image](http://farm2.static.flickr.com/1237/526143188_225092212e.jpg)
I then located a grounding point for the O2sim to fix to, there is a nice handy one just inside the engine bay:
![Posted Image](http://farm1.static.flickr.com/212/526143148_eb49cec8e2.jpg)
Next was to actually fit the 02sim. I noticed that my lambda which has been replaced by a Bosch one has the black and grey wires reversed to the standard one, not a problem the position of the wires in the socket is important not the colour!.
Also the red O2sim wire is spliced to the white wire, in the picture it looks like the I've joined the white wire and the red wire but the wire wire continues out of the blue connector block and then into the yellow sleeve, its just hidden in the photo.
![Posted Image](http://farm1.static.flickr.com/214/526232171_50012d1ac2.jpg)
All fitted I plugged back in the lambda and turned the ignition on and the green light FLASHES
![:)](http://www.vx220.org.uk/forums/public/style_emoticons/default/smile.png)
![Posted Image](http://farm2.static.flickr.com/1089/526232193_11eb9df89b.jpg)
I've now pulled the fuse for the ECU to make it reset, this will make the light go out but to test fully you have to put some miles on the car could be 40 could be 400!
Edit:
Car is all back together and no EML
Hi,
Looking at the wiring of a Lamda-sensor, I would say that the grey wire to the ECU would benefit from being connected to the black-wire of the O2-sim. That ties signal-ground to the earth connection of the O2-sim.
If you don't then I can see that the O2-sim signal wire may drift a little in relation to the signal-earth and maybe bring the light on.
Do you need the heater wires still connected to the old sensor, or can you disconnect them without bringing on the light? It would be nice to be able to repace the old sensor with a bolt.
Steve
Steve,
I see you point but others have just connected the O2sim black wire to the chassis.
Not sure about your question, I have ordered the heat resistor option as well but it did not turn up at the same time as the 02sim. It seems others have fitted just the 02sim and others both the O2sim and the heater resistor, but as you say if you fit both you are effectively by passing the lambda totally and it could be removed and a bolt put in (I think!)
Edited by urbanmac, 02 June 2007 - 02:47 PM.
