Dash Removal / Replacement
Posted 13 April 2005 - 11:44 AM
Posted 13 April 2005 - 11:46 AM
Posted 13 April 2005 - 12:48 PM
Posted 13 April 2005 - 01:17 PM
Posted 13 April 2005 - 03:58 PM
Posted 13 April 2005 - 05:54 PM
Oh, and when you've spent 10 mins trying to get the dash to move, remove the 4th screw that's hiding over the light switch cluster.
Posted 13 April 2005 - 06:24 PM
Posted 13 April 2005 - 07:09 PM
Posted 13 April 2005 - 10:36 PM
I now start my car with a paper clip
Posted 18 April 2005 - 09:01 AM
Screw locations are shown in the attached photos.
Posted 18 April 2005 - 09:02 AM
Posted 26 November 2006 - 06:08 PM
I have a 05 VXT and apparently that has a 6th dash screw - in an attempt to 'fix' the lifting dash issue vauxhall have riveted another bracket behind the vx220 logo panel. To get at it I had to drill out the rivets for the logo and velcro it back on later.
At least I now have a working Ipod lead to the pax cubby hole and a hard wired snooper to show for my efforts.
Posted 26 November 2006 - 09:20 PM
Having just spent the afternoon upside down in the foot wells, I thought I better add a bit to this thread.
I have a 05 VXT and apparently that has a 6th dash screw - in an attempt to 'fix' the lifting dash issue vauxhall have riveted another bracket behind the vx220 logo panel. To get at it I had to drill out the rivets for the logo and velcro it back on later.![]()
good tip.
My dash will be cmoing off (again) next weekend as I will be installing a new Alpine HU (the iPod Full speed one), some front speakers and adding leds behind the heater controls.
Posted 11 February 2008 - 09:43 PM
anyone know if this is true for 04's ?
Posted 11 February 2008 - 10:14 PM
I did this yesterday, mine is an 03 and only had 4 screws.
One thing I found that no one mentiond was the top stack surround actually hooks in a slot in the dash which can make it a bit tricky to remove the dash.
I couldnt see how you were supposed to get it off so brute force was the order of the day
Im sure it wasnt supposed to bend that way!!!
Edited by james141, 11 February 2008 - 10:16 PM.
Posted 11 February 2008 - 10:17 PM
Yep and even harder trying to get it to clip back in place!!
Posted 11 February 2008 - 10:20 PM
I actually thought that when I finally got it off but it went back on quite easly, I have probably bent the metal slot thing
Also as a side note my heater seems to work a lot better since I have removed and refitted the dash, I get loads more air
Posted 12 February 2008 - 09:28 AM
I actually thought that when I finally got it off but it went back on quite easly, I have probably bent the metal slot thing![]()
Also as a side note my heater seems to work a lot better since I have removed and refitted the dash, I get loads more air![]()
I've noticed the exact same thing!
Posted 13 February 2008 - 02:19 PM
Posted 13 February 2008 - 02:38 PM
ive got the 4 screws out, got the dash part loose however its stuck on the cowling for the fake stack
bit wrried its just going to rip the instrument pod out
Try and pull the stack binnacle towards you at the same time as lifting the dash up. Bit of force and it'l come out.
